Weird Brake Sound
Old Jun 21, 2005 | 05:38 PM
Sassafrass's Avatar
Default Weird Brake Sound
I just got my new brake setup, its a modified teg 4 wheel disc systems
I have had it over about a week now, and I am just now starting to hear this sound. It occurs when I lightly apply the brake, once I go with more force it stops, and it also makes the same sound sometimes when I turn, (mostly right) Its a very high pitched metal on metal type sound, but its not very loud, but definatly loud enough to notice.
Pads are almost brand new, same with the rotors, anyone got any suggestions?
Old Jun 21, 2005 | 06:05 PM
h kid's Avatar
Default Re: Weird Brake Sound (Sassafrass)
same thing happened to my eg when i swapped to si disc brakes in the back, haven't fixed it in about 5 months but i think it might be the proportioning valve( just a guess i think maybe there is more force on the front and it barely grabs on the back and makes kind of a slight scratching sound.
Old Jun 21, 2005 | 06:09 PM
papito_85's Avatar
Bump, I have the same problem. It's very annoying.
Old Jun 21, 2005 | 06:21 PM
h kid's Avatar
Default Re: (papito_85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papito_85 &raquo;</TD></TR><TR><TD CLASS="quote">Bump, I have the same problem. It's very annoying.</TD></TR></TABLE> i know but i got used to it (im lazy) but did you guys change you proportioning valve from a 99-00 si? that might be our problem, not inuff fluid to the back disc.
Old Jun 21, 2005 | 06:23 PM
Stoich EG2's Avatar
Default Re: (h kid)
did you guys check and see if the heat shield isn't touching the discs? same thing happened with my accord, it was rubbing from the bottom.
Old Jun 21, 2005 | 06:30 PM
h kid's Avatar
Default Re: (h kid)
thats what i thought too but i checked that and no its not that so then i thought maybe the disc needs to be resurfaced or the prop valve but havent done either because it works and ive gotten use to the slight noice coming from the back so maibe later.
Old Jun 21, 2005 | 10:28 PM
Sassafrass's Avatar
Default Re: (h kid)
thanks for the infor guys, I'm gonna check the dust guard tommorow, then get a new prop valve hopefully fixes the problem. Way tooooo annoying for me
Old Jun 21, 2005 | 10:45 PM
Jimmy's Avatar
Global Moderator
Are your little brake pad clips there?
I'm thinking maybe one of them isn't there and it's allowing the brake pad to be loose and move around and cause brake chatter/noise..been there, done that!
goodluck.
Old Jun 21, 2005 | 10:59 PM
h kid's Avatar
Default Re: (Sassafrass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sassafrass &raquo;</TD></TR><TR><TD CLASS="quote">thanks for the infor guys, I'm gonna check the dust guard tommorow, then get a new prop valve hopefully fixes the problem. Way tooooo annoying for me</TD></TR></TABLE>
let us know on the prop valve that way i know for sure that it is the prob and i can get motivated to replace it.
Old Jun 22, 2005 | 10:20 AM
Sassafrass's Avatar
Default Re: (h kid)
I checked the dust shield today, and thats definatly not the problem, I guess next step is a new prop valve, will keep u updated.
Old Jun 24, 2005 | 12:18 PM
Sassafrass's Avatar
After driving for a longer period of time, I really do not think a new prop valve will do anything. Its the front pads must be rubbing or moving when they shouldnt be. Anyone know what could be causing this?
Civic_07
Mar 25, 2008 04:21 PM
RP215.
May 2, 2006 11:13 AM
oldsklcrx
Aug 22, 2005 01:32 AM
EJ1 wilcox
Aug 15, 2004 03:57 PM
vietboixstunnah
May 10, 2003 01:00 PM
