blown head gasket?
Old Jun 21, 2005 | 04:27 PM
civicracer59's Avatar
Default blown head gasket?
Is oil in the coolant resevoir and bluish white smoke from the exhaust under hard accerleration and high rpm's definetly signs of a bad head gasket on a d15? Any help is appreciated. Thanks
Old Jun 21, 2005 | 04:50 PM
maxspeedhonda's Avatar
Default Re: blown head gasket? (civicracer59)
Yes, check your oil for milkshake as well.
Old Jun 21, 2005 | 04:57 PM
Default Re: blown head gasket? (maxspeedhonda)
oil isnt milkshake yet but just changed it two days ago. I only drive 2 miles to work everyday is it going to hurt it if i drive it to work and back for 2 months till i get my b16 put it? Or any temporary miracle potions for it? thanks
Old Jun 21, 2005 | 07:12 PM
really depends on how severe it is. Do you feel a loss in power?
Old Jun 21, 2005 | 07:35 PM
RedlinedVTEC's Avatar
Should be ok just driving to and from work that short distance. Just keep an eye on your oil. And if you have to you're only looking at around $70 in parts to do the headgasket (bare minimum: new headgasket, can of copper spray, gallon of coolant, oil and filter).
Old Jun 21, 2005 | 08:22 PM
PrettyLude's Avatar
is it overheating?
Old Jun 22, 2005 | 01:51 PM
Default Re: (PrettyLude)
It only overheats after driving for about ten minutes and even then it doesnt peg, the needle just goes up almost to the max but it never pegs out. There is a little loss of power, mainly a bad miss, but after I changed the fouled plugs it runs fine again for about another 100 miles or so then plugs are fouled again.
Old Jun 22, 2005 | 05:49 PM
lsvtecracer's Avatar
Default Re: (civicracer59)
Since you going to yank this motor out anyway, you can tried a can of K&W block seal. Just follow the instructions and put it in the radiator. Make sure you follow the instruction because if you do it wrong, it will clog your radiator. It has work in many of my customer car and it will help stop the miss. Since you only used to drive to work, it should help you out for the time being.
Old Jun 23, 2005 | 03:02 PM
Default Re: (lsvtecracer)
Thanks everybody for your help im sure ill be back with more questions when i go to drop my b16 in.
JdmJah
16
Feb 19, 2013 06:42 PM
DRoylflush
11
Apr 10, 2011 02:11 PM
ericstambaugh07
Jun 25, 2007 09:08 AM
PatrickGSR94
Mar 5, 2003 10:02 PM
GSG2
Jul 27, 2001 06:52 PM
