HELP identify a OBD2b B16a wiring harness
Old Jun 21, 2005 | 11:36 AM
satitus's Avatar
Default HELP identify a OBD2b B16a wiring harness
So I bought a OBD2b wiring harness from a guy on ebay (I will refrain from using his name at this point). He claimed it was uncut and nothing was broken. Hardly the truth, several broken/missing plugs and spliced wires. It looks nothing like a typical 99-00 si harness. Anyway, could someone please help me identify the harness. The injector clips are grey not black. Does anyone know if the 99-00si harness ever had grey injector clips? Would posting a pic of the clips help ID it? Is there an easy way to ID the harness?
thanks
Old Jun 21, 2005 | 11:41 AM
handa's Avatar
Default Re: HELP identify a OBD2b B16a wiring harness (satitus)
please post the pic of the harness. maybe a pic of the injector clip because the clips have different grooves on them between obd's.
Old Jun 21, 2005 | 12:02 PM
satitus's Avatar
Default Re: HELP identify a OBD2b B16a wiring harness (handa)
Here is an injector on a clip :
http://www.we-todd-did-racing....D.jpg:
here is a broken clip::
Modified by satitus at 4:24 PM 6/21/2005
Old Jun 21, 2005 | 12:40 PM
hatchi's Avatar
that looks like an obd1 injector clip because it has the metal clip to hold the injectors. the obd2b has black clips and doesnt have a metal clip. it might have been soldered on the harness to run obd1 injectors. The obd2b engine harness is a one piece going straight to the ecu and it has 4 plugs 3 for ecu and 1 little green plug
Old Jun 21, 2005 | 12:45 PM
satitus's Avatar
Default Re: HELP identify a OBD2b B16a wiring harness (hatchi)
Well, it does have 2 plugs for the ECU (the third is missing, part of the chassis harness) as well as a little green plug so I think it is OBD2 (a or b not sure). What about a GSR harness? I believe that they have grey injector plugs. Is there a sure fire way to identify a harness?
BoostinEJ1
Apr 3, 2006 12:41 PM
turboteg2nv
Nov 20, 2005 06:07 PM
dutchman5
Sep 22, 2005 03:42 PM
abmerop18
Feb 19, 2005 05:43 PM
95excoupe
Nov 14, 2004 10:03 PM
