did a compression test are these numbers okay
Old Jun 21, 2005 | 10:44 AM
siregcivic's Avatar
Default did a compression test are these numbers okay
i have a 92 civic cx hatch with a 94 d16z6 with 140,XXX on the motor
i did a compression test did it 3 times on all cylinders with the fuse for the ecu unplugged and the dizzy unplugged at wot
118-127-123-148
are those numbers okay??
i thought it was supposed to be a bit higher
any info would be great
Old Jun 21, 2005 | 10:50 AM
EJ1 wilcox's Avatar
Default Re: did a compression test are these numbers okay (siregcivic)
Those numbers look pretty low... time for a rebuild?
Old Jun 21, 2005 | 11:33 AM
flood's Avatar
your looking for even numbers across teh board.
You don't have even numbers. Does it smoke at all?
Old Jun 21, 2005 | 11:38 AM
EK_GSR's Avatar
Default Re: did a compression test are these numbers okay (flood)
as long they are all within 5PSI of each other it is okay... but those have highs and lows with a difference of 30 PSI .... i would say time for a rebuild.
my compression was 184-183-187-185 for a b18c low compression.
Old Jun 21, 2005 | 11:57 AM
siregcivic's Avatar
Default Re: did a compression test are these numbers okay (EK_GSR)
yeah it burns about a quart every 4-700 miles depending on how hard i drive it
i can get single cam motors for 300 should i just buy another one, or spend the money in p29 88-89 integra pistons and rings?
Old Jun 21, 2005 | 12:00 PM
komat's Avatar
that means your piston rings are shot
i had a headgasket problem with my cx and still had 150psi on all 4
JDM-EJ1's Avatar
Wow, those numbers are way too low. Looks like it's time for a new motor or a rebuild.
Old Jun 21, 2005 | 12:02 PM
Convoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK_GSR &raquo;</TD></TR><TR><TD CLASS="quote">as long they are all within 5PSI of each other it is okay... but those have highs and lows with a difference of 30 PSI .... i would say time for a rebuild.</TD></TR></TABLE>
Actually is should be +/- 20psi
check it out http://www.c-speedracing.com/h...t.php
Old Jun 21, 2005 | 12:07 PM
Jon D's Avatar
consistency is always key....you have some variation there i would definitely be concerned about.
Smash03
Aug 24, 2008 11:21 PM
lude98SH
Sep 30, 2007 09:17 AM
stockb18c
Oct 13, 2006 08:52 AM
bucdenny
May 9, 2005 04:30 PM
EF8_SiR
Jul 20, 2003 10:24 PM
