What happens to your allignment when you raise or lower a car?
Old Feb 12, 2002 | 08:22 AM
CivicSiRacer's Avatar
Default What happens to your allignment when you raise or lower a car?
Specifically what happens to toe? I forget which way it goes when you lower a car. Is it toe-out when you lower a car and toe-in when you raise a car?
Thanks!
Mike
Old Feb 12, 2002 | 08:32 AM
Drew M's Avatar
New User
Default Re: What happens to your allignment when you raise or lower a car? (CivicSiRacer)
Depends on the location of the steering arms in relation to the pivot point for the wheels. The suspension compresses and shortens its length (because it comes closer to the car in its arc) in relation to the steering arm which stays a constant length and pushes the tire out. If the steering gear is behind the pivot the back of the tire is pushed outward.
Crazydave's Avatar
If I remember right...
It gets toed in on my civic when I crank neg camber in
Old Feb 12, 2002 | 10:02 AM
Default Re: What happens to your allignment when you raise or lower a car? (Cobra)
Ok well this is for a 2000 Honda Civic Si. Does that help?
Madukes
Jan 18, 2010 07:43 PM
Late Riser
Suspension & Brakes
Jun 2, 2009 06:56 AM
The Bster
Dec 21, 2007 09:44 AM
Shirozu
Nov 27, 2005 03:17 PM
balistic CRX
Jan 22, 2002 05:19 PM
