LEAN in boost.. sounds newb. but take a look
Old Jun 20, 2005 | 04:29 PM
B20luda's Avatar
Default LEAN in boost.. sounds newb. but take a look
i have a small problem with my car..the engine leans way out up top in boost like 14.5-17.1 at around 10psi im using Hondata S200B DSM 450cc injectors stock pressure regulator and a Walbro 255LPH fuel pump it doesnt start leaning out until around 5k RPM..the car is a 90 prelude with a built B20a sleeved 83.5mm bore has a ported head with larger stainless valves stock cams stock intake manifold...dynoed before all these mods at 240whp on 11psi im runnin 10 now..how could i be maxxing these injectors out..any ideas why it leans out? i dont think im making enough HP to max out the injectors and BTW i dont drive it lean in boost..
Old Jun 20, 2005 | 04:38 PM
OMG B16's Avatar
How was the car tuned? Dyno? Stret?
Old Jun 20, 2005 | 04:41 PM
m R g S r's Avatar
Default Re: LEAN in boost.. sounds newb. but take a look (B20luda)
whats the fuel pressure? maybe it's low
and dsm's are good to about 300whp...ive seen em pushed to about 330whp.....
Old Jun 20, 2005 | 05:13 PM
adseguy's Avatar
Default Re: LEAN in boost.. sounds newb. but take a look (m R g S r)
this happened to me too. It just so happened that my wideband sensor died on me. I knew it wasn't LEAN because otherwise I would have blown up and i pulled the plugs they are normal....check out the sensor, it could be the problem if you haven't changed anything
Old Jun 20, 2005 | 06:02 PM
deftones0817's Avatar
Default Re: LEAN in boost.. sounds newb. but take a look (adseguy)
maybe the main relay is ******* up? I had my car go lean in boost when the main relay started to die in the heat and **** and it being old
non-VTEC
Mar 20, 2006 05:41 PM
SpeedingHatch
Dec 31, 2005 02:41 PM
project civic
Sep 5, 2005 04:07 PM
turbo*s2k
Feb 25, 2004 11:50 AM
freakie
Nov 8, 2001 08:39 AM
