Automatic 1990 civic 4 door problem with shifter in park.
Old Jun 20, 2005 | 04:19 PM
julio_bOostamante's Avatar
I'm a Jackass
Default Automatic 1990 civic 4 door problem with shifter in park.
When i go to try and get the car to drive it wont go anywhere. however i can get it in gear if i use the key to disengage it. its like the locking mechanism is stuck or is not gettting the signal it needs to operate on its own. i checked all my fuses and all seem to be working properly. could it be a relay? if so where can i find it?
thanks for your help
Old Jun 20, 2005 | 04:54 PM
Machine1's Avatar
Default Re: Automatic 1990 civic 4 door problem with shifter in park. (julio_bOostamante)
Check to see if your brake lights work when you depress the brake pedal. If not, then it's your stop lamp switch, it controls the shift interlock also.
Old Jun 20, 2005 | 04:57 PM
blah13's Avatar
Default Re: Automatic 1990 civic 4 door problem with shifter in park. (Machine1)
Yup, when you hit the brake you should hear a click..mine went bad on my dx so I took off the console and chopped the thing off, no need to put a key in the override all the damn time.
Old Jun 21, 2005 | 10:58 AM
I'm a Jackass
Default Re: Automatic 1990 civic 4 door problem with shifter in park. (blah13)
i take it its a bitch to remove? how do i disable it withou having to cut off ****?
thanks!
Old Jun 21, 2005 | 07:06 PM
Newman's Avatar
New User
It's just 2 wires that go onto the fuse block under the dash. I'd advise against it for safety reasons but it can easily be bypassed.
Old Jun 21, 2005 | 07:43 PM
wankel kel's Avatar
Im having the same problems on my dx auto
i noticed it blows the rear passenger bulb every once and a while.I may just cut the wires for now.
Old Jun 22, 2005 | 10:29 AM
I'm a Jackass
Default Re: Automatic 1990 civic 4 door problem with shifter in park. (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">It's just 2 wires that go onto the fuse block under the dash. I'd advise against it for safety reasons but it can easily be bypassed.</TD></TR></TABLE>
you mean that gry block of fuses and ****?
hmmm i will have to look at that. thanks again!
Old Jun 22, 2005 | 12:16 PM
djsire's Avatar
HEy dont cut the wires. just go and buy the damn bulb. it like 2 dollars. then you dont have to worry about cops pullin you over.
Old Jun 22, 2005 | 04:41 PM
Machine1's Avatar
This is a picture from underneath the dash,
The thin bar in the middle is the brake pedal, next to the steering column covering, the brake switch is at the top of the brake pedal.
The duct tape is there because the plug that was on the brake pedal to depress the switch has deteriorated and fell out.
Your car should look similar underneath except it won't have a clutch pedal on the left.
Old Jun 23, 2005 | 05:18 PM
I'm a Jackass
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Machine1 &raquo;</TD></TR><TR><TD CLASS="quote">
oh man, you da man! i Heart you now..lol
thanks
mattyk85
Aug 20, 2007 05:05 PM
Entaka
Aug 17, 2007 10:03 PM
jsselee
May 20, 2006 04:38 PM
bobobram
Aug 2, 2005 11:47 AM
SilverDc2
Jan 6, 2003 01:43 PM
