need help ASAP!!!!!
Old Jun 20, 2005 | 12:19 PM
game over's Avatar
Default need help ASAP!!!!!
this car is a nightmare....the car has ls vtec and it is smoking like a train....i have changed.....the headgasket,valve seals,and the head was resurfaced .it has the plug in the head.im running out of ideas can u guys help me out
Old Jun 20, 2005 | 12:45 PM
Suck my DX's Avatar
Default Re: need help ASAP!!!!! (game over)
where is the smoke coming from...u might have bad rings...do a leakdown check for a positive answer..good luck
Old Jun 20, 2005 | 12:48 PM
game over's Avatar
i have changed blocks and it has done the same thing.....one of the blocks was brand new rebuild
Old Jun 20, 2005 | 12:55 PM
Suck my DX's Avatar
Default Re: (game over)
where is the smoke coming from...who did the work...it could be improper installation..there shouldnt be smoking with a freshly rebuilt block with new valve seals,headgasket,and resufacing of the head...have u done a compression or leakdown test yet?
Old Jun 20, 2005 | 01:14 PM
game over's Avatar
no not yet
Old Jun 20, 2005 | 02:35 PM
game over's Avatar
ttt
Old Jun 20, 2005 | 02:37 PM
slomofo's Avatar
GDD Member
Bad install job.
Old Jun 20, 2005 | 03:02 PM
game over's Avatar
how is that
Old Jun 20, 2005 | 03:42 PM
Suck my DX's Avatar
dude think of it...u say that it is a freshly built block...so rule that out...u also say that the head has been resurfaced..u changed the valve seals...and changed the head gasket..so rule out the top end...u probablyy messed up somewhere...if ur worried about the block and head having imperfections, spray the headgasket with copper spray next time...
ive already asked u twice but still no answer...where is the smoke coming from? if u would actually supply some more info it would make diagnosing ur problem a lot easier..
Old Jun 21, 2005 | 07:18 AM
game over's Avatar
its coming from the exhaust and its smells like oil....
Old Jun 21, 2005 | 10:57 AM
game over's Avatar
just did a compression test.... and the rings are good
Old Jun 21, 2005 | 12:01 PM
slomofo's Avatar
GDD Member
I have a feeling that you or your mechanic sucks and it's your head gasket.
Old Jun 21, 2005 | 02:13 PM
Suck my DX's Avatar
Default Re: (slomofo)
u sure u replaced the valve seals...or are u just saying that...white smoke out ur exhaust is valve seals...maybe u fucked up when installing them...
Old Jun 21, 2005 | 06:25 PM
game over's Avatar
thats funny.... the head gasket was changed and the problem was still there
Old Jun 21, 2005 | 06:32 PM
slomofo's Avatar
GDD Member
Which head gasket did you use? LS or VTEC?
Old Jun 21, 2005 | 06:38 PM
Suck my DX's Avatar
r u sure ur valve seals were installed properly?
Old Jun 22, 2005 | 07:18 AM
game over's Avatar
cometic hybrid head gasket...and yes the seals are done right
mf1990
Jun 17, 2009 09:11 PM
9t4fodo
Feb 3, 2009 01:09 PM
90datech
May 28, 2007 06:18 PM
charlie_sohc
May 1, 2006 06:08 AM
BoogiepopJDM
Jan 23, 2006 10:38 AM
