Help with seized bolts
Old Jun 20, 2005 | 11:33 AM
Blazin Civic's Avatar
Default Help with seized bolts
Being most of our cars are 10-13 years old rust is definetly an issue in the chasis. Anyone have any good advice for removing seized up bolts. I have an impact gun and wd-40 and I still can't get my driver side rear strut out. The bolt that holds it to the control arm wont move for ****.
Old Jun 20, 2005 | 11:51 AM
AutoXer's Avatar
Default Re: Help with seized bolts (Blazin Civic)
WD-40 sucks as a penatrating lube. Use PB-Blaster.
Might have to get out a torch as well.
Old Jun 20, 2005 | 11:56 AM
Rodney's Avatar
I forgot more about hondas then you will ever know....
From: hop,skip, and a jump from the city,, new friggin york, USA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote">Anyone have any good advice for removing seized up bolts. </TD></TR></TABLE>
use a torch. get the collar (center of the bushing, most likely where she is stuck) nice and hot, then hit it with the gun. it will come out. i suggest having new bushing/control arm/bolts on hand and most likely you will need them.
Old Jun 20, 2005 | 01:18 PM
h22 civic's Avatar
Default Re: Help with seized bolts (AutoXer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AutoXer &raquo;</TD></TR><TR><TD CLASS="quote">WD-40 sucks as a penatrating lube. Use PB-Blaster.
el torcho and 711 penetrating lube
Old Jun 20, 2005 | 01:23 PM
_BEN_'s Avatar
Default Re: Help with seized bolts (h22 civic)
Brake cleaner works good too.
Anything you spray on it won't do you any good unless you let it soak in. So if you are planning on doing some work, crawl under your car and give everything a shot the night before.
Old Jun 20, 2005 | 01:25 PM
Default Re: Help with seized bolts (Rodney)
You are saying you need new controls arms to put suspension on? That seems a little rediculous.
Old Jun 20, 2005 | 02:03 PM
Ok I got a torch now....how long am I supposed to keep a torch on the bolt before trying to remove it. I don't want to ruin anything.
Old Jun 20, 2005 | 02:52 PM
Ok I torched the ever living **** out of this thing and it still wont budge
Old Jun 20, 2005 | 03:00 PM
Rodney's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote"> You are saying you need new controls arms to put suspension on? That seems a little rediculous.</TD></TR></TABLE>
bushings on our cars are old/crusty, especially in the ny climate. unfortuneatly, they seize to the bolts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blazin Civic &raquo;</TD></TR><TR><TD CLASS="quote">Ok I got a torch now....how long am I supposed to keep a torch on the bolt before trying to remove it. I don't want to ruin anything.</TD></TR></TABLE>
again, you are most likely going to need new bolts/bushings at the very least. if you are torching the collar in the bushing, you WILL damage the bushing and it will need to be replaced. you are saying you torched it, with a propane torch? those suck. also, where did you heat it? where in ny are you?
Old Jun 20, 2005 | 03:01 PM
is there any way for me to just cut the thing out or something?
Old Jun 20, 2005 | 03:11 PM
Coppertop's Avatar
why would you torch the bolt, you only make the bolt expand and it gets more stuck, heat the area around the bolt, and ease her out. and i think a breaker bar would work a lil better than an impact gun
Old Jun 20, 2005 | 03:15 PM
kkim's Avatar
did you try pb blaster, liquid wrench or some other penetrant designed to loosen frozen bolts as suggested? wd-40 just wont cut it.
also, you need to apply the penetrant several times over a couple of days to give it a chance to soak in... and use a lot. careful, though... this stuff is flammable.
Built B16A
May 26, 2006 11:58 AM
d15b2_T
Apr 20, 2006 04:18 PM
DC4_MADMAN
Suspension & Brakes
Sep 7, 2005 09:22 AM
Dragline
Jul 12, 2005 04:46 PM
_Cyclone_
10
May 16, 2005 01:15 PM
