turbo on automatic?
Old Jun 20, 2005 | 09:48 AM
pkxfashion's Avatar
Default turbo on automatic?
I got an acura CL, automatic with sport shift. I'm looking to add some boost, i was wondering if it would be possible to do so, since the car is not a true manual?
Old Jun 20, 2005 | 10:19 AM
Blanket Jackson's Avatar
Default Re: turbo on automatic? (pkxfashion)
Yes you can boost it. No you can't put alot of boost on it.
I know this is comparing apples to oranges, but I have a 1999 Eclipse Spyder GS Automatic, that I did a full DOHC head swap and turbo kit install. I am only running 10psi, but I wanted to be safe. I looked into a shift kit just to be safe, and I found a company called Translab. I bought the Stage 4 upgrade which should be safe for up to 400hp.
I am sure there are companies that carry these so called shift kits, but I am sure, if you run low amounts of boost, your transmission should be some-what ok.
There is one good thing to boost on an automatic-when accelerating slowly the car seems non-turbo because between shifts, they BOV does not expel excess boost. The car slws the rev's automatically.
Shaughn
Old Jun 20, 2005 | 11:29 AM
pkxfashion's Avatar
Default Re: turbo on automatic? (SlowSpyder)
hmm sounds good.
I'll look into translab, see if they make a kit for the CL.
thanks for the help.
McLude2nR
Feb 4, 2007 02:40 PM
2point3h22lude
Sep 10, 2005 08:48 PM
silverb18
Sep 22, 2004 02:37 PM
eg686
Nov 19, 2003 12:55 PM
HybridCoupe
Oct 31, 2002 12:47 PM
