JDM ITR header and high flow cat
Old Jun 20, 2005 | 08:46 AM
LatinEM2's Avatar
Default JDM ITR header and high flow cat
Well i just purchased a JDM ITR header from a seller here..and i want to order a high flow cat..prolly will go with the carsound high flow..question is..will it bolt up to my Comptech cat-back...i know i need the 2.5 inlet catalic..what about the outlet? 2.5 also? will that bolt to my Comptech 60 mm? TIA.. and am i going to get a CEL? all for my 00 CIvic Si..
Old Jun 20, 2005 | 01:26 PM
tthumma10's Avatar
Default Re: JDM ITR header and high flow cat (LatinEM1)
I was wondering the same thing...any 2.5" collectored (?) header with 60 mm exhaust piping. Will a 2.5" cat work, or are there any special modifications needed?
Old Jun 20, 2005 | 01:52 PM
Padawan's Avatar
Darth ModerVader
A 2.5" inlet/outlet cat with the proper flanges will bolt up with no other modifications. I'd suggest contacting David at SMSP to inquire about his newest cats. Flow testing shows them to be excellent performers.
Old Jun 20, 2005 | 01:55 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: JDM ITR header and high flow cat (Padawan)
I purchased an SMSP cat actually for my JDM ITR header. The cat itself is great, but the flange is awful. Its just a piece of pipe welded to the cat thats flared at the end, with a slip over flange. Doesn't make a good seal at all and pushes my exhaust too far back so it rattles against everything. I recommend the SMSP Cat definatly, but order a 2.5" flange and donut gasket from JHPUSA.com or wherever, and have it welded to fit.
Old Jun 20, 2005 | 02:20 PM
Padawan's Avatar
Darth ModerVader
Default Re: JDM ITR header and high flow cat (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej &raquo;</TD></TR><TR><TD CLASS="quote">I purchased an SMSP cat actually for my JDM ITR header. The cat itself is great, but the flange is awful. Its just a piece of pipe welded to the cat thats flared at the end, with a slip over flange. Doesn't make a good seal at all and pushes my exhaust too far back so it rattles against everything. I recommend the SMSP Cat definatly, but order a 2.5" flange and donut gasket from JHPUSA.com or wherever, and have it welded to fit. </TD></TR></TABLE>
I never had any problems with the flange on my SMSP cat. Did you contact Dave about the problem?
Old Jun 20, 2005 | 03:16 PM
Stillmatic22's Avatar
I had the same problem. I just ordered a 2.5" carsound to mate with my JDM mugen header (2.5" collector), and was unsure if the 2.5" 3-bolt flange would match up with the flange on my apexi world sport catback....it will. The flange/bolt pattern are the same size, it's only the circumfirence of the whole that is larger. So I (we) will have a slight bottle-neck effect there. (60mm= 2.3xx. ) Due to the fact that it is going from 2.5" to the 60mm piping. Sucks a little for me atleast since my world sport is a chambered exhaust as it is. I may down the line purchase new 2.5" piping from kteller.com. That way I can change just the mufflers as I please and not worry about the piping.
kteller.com has the flanges/gaskets you will need, if you do not already have them. Hope this helps
Old Jun 20, 2005 | 03:52 PM
LatinEM2's Avatar
Default Re: JDM ITR header and high flow cat (Stillmatic22)
thanks for the replies guys..
Old Jun 21, 2005 | 10:28 AM
LatinEM2's Avatar
does anybody know how long the cat will have to be in order for it to bolt up and reach my Comptech cat-back? will the outlet flange from the cat need to be welded on or just bolted on?
Old Jun 21, 2005 | 10:42 AM
SkoundrelUSA's Avatar
cute little bastard
So, will a 2.5" cat bolt up to any catback? (Magnaflow for me)
jeremy_dane
Feb 20, 2009 09:07 AM
bigedx
Nov 4, 2003 03:50 AM
B_1_8_hatch
Mar 20, 2003 10:56 PM
