Aluminum Exhaust - Will it last on a Daily Driver?
Old Jun 20, 2005 | 08:36 AM
Del Sol's Avatar
Default Aluminum Exhaust - Will it last on a Daily Driver?
Hi everone, I found a few old threads on using aluminum for the exhaust piping. I know Geoff from full race had an all ally exhaust, and a few other ppl said they are running one too. What I want to know is have these exhausts held up ok? Will it last on a daily driver?
Also what do you guys do for mufflers? Fabricate one from ally, or weld flanges and put on a normal stainless muffler? Thanks in advance...
Old Jun 20, 2005 | 12:10 PM
Tad's Avatar
Tad
where do you live?
if ur in cali i probly wouldnt worry
Old Jun 20, 2005 | 05:10 PM
Del Sol's Avatar
Default Re: (Tad)
I live in Australia!
But the weather here is very similar to Cali, never goes below about 8 degrees C. Salt is never used on the roads, so thats not a problem. Even mild steel systems last ok here. I was mainly concerned about wether the ally would stand up to the temprature and thermal cycling of the exhaust? If they last ok I will pull out the tig and start work
Old Jun 20, 2005 | 05:33 PM
onesikcivic's Avatar
it would probably work, but why not just use mild steel or something a little heavier to be on the safe side, why do all that work and then have a problem, but ya it should be ok
Old Jun 20, 2005 | 09:26 PM
Tad's Avatar
Tad
Default Re: (onesikcivic)
hmm, yeah i mean.. what could happen to it really?
I don't think it'll get as hot as a header does
maybe if you had some crazy high hp beast,
like one of those turbo cars that you can see the exhaust manifolds glowing red in the dark.
**** arent pistons made out of aluminum??
Old Jun 20, 2005 | 10:54 PM
RangerJoe's Avatar
forged aluminum is slightly different than 6061 alum piping.
I would keep your header runners SS or iron or something like that, but catback, you shouldnt have a problem running aluminum tubing
Old Jun 21, 2005 | 12:42 AM
Tad's Avatar
Tad
Default Re: (RangerJoe)
hAH i wish i had forged pistons
i'm talkin cast stuff
but yeah, you said it right, catback
Old Jun 21, 2005 | 07:56 AM
Del Sol's Avatar
Default Re: (Tad)
Ok cool, so alluminium catback. What about the muffler? Should I try fabricating one from alluminium?
Old Jun 27, 2005 | 01:22 AM
RangerJoe's Avatar
dont make your own muffler, buy something.
Old Jun 27, 2005 | 01:41 AM
Del Sol's Avatar
Care to post some links to ready made alluminium mufflers?
I don't think making it is a problem. I have a decent AC inverter TIG. A few people have already done it. The discussion has kinda moved to this thread now: https://honda-tech.com/zerothread?id=1286471
Dr Pooface
Welding / Fabrication
15
Feb 7, 2012 06:21 AM
big-cat
Mar 20, 2007 08:05 AM
Tyler H
41
Jun 13, 2005 11:17 AM
CRVRX
14
May 7, 2005 10:08 AM
riceburnerryan
Nov 22, 2004 11:49 AM
