Turbo si
check the website for more info, though I suggest getting K pro http://www.revhard.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si 02 »</TD></TR><TR><TD CLASS="quote">u suggest the k-pro? my friend has been telling me hondata, why do u suggest that?</TD></TR></TABLE>
silly rabbit. tricks are for kids.
k-pro is a model from hondata. the same goes for the k100. the revhard kit, i believe, only comes with a reflash chip.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03ephatch »</TD></TR><TR><TD CLASS="quote">the revhard kit, i believe, only comes with a reflash chip.</TD></TR></TABLE>
No, you must send your ECU to be reflashed, it doesnt come with any Chip. That is unless you order a bag of doritos at the same time.
The reflash from Revhard has not gotten the most solid of reviews. Some people drive off fine for months, though others start throwing CEL's after only a few miles. Getting the K-pro will allow you to do complete tuning and have room to increase boost down the road, though proper tuning is the key so dyno tune with a professional.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Huggy Bear »</TD></TR><TR><TD CLASS="quote">No, you must send your ECU to be reflashed, it doesnt come with any Chip. That is unless you order a bag of doritos at the same time.</TD></TR></TABLE>
yeah that... and a bag of chips
If you have smog testing in your state you may run into problems with guardian (the program cybernation uses for tuning of their turbo kit) if they check your OBD port for engine and emission errors, though with cybernation you can still go the K pro route if you want, but the main advantage to cybernation IS guardian so it's sort of a toss up.
ultradx
Aug 9, 2005 01:32 PM
