How do you make your a/c blow colder and heat blow hotter?
Old Jun 19, 2005 | 08:03 PM
SloCrxDx91's Avatar
Default How do you make your a/c blow colder and heat blow hotter?
In my car it doesn't heat well or blow cool air. I am thinking or have been told........
new fan, recharge a/c, new heater core, or thermastat
Old Jun 20, 2005 | 09:46 AM
JimBlake's Avatar
Default Re: How do you make your a/c blow colder and heat blow hotter? (SloCrxDx91)
Any of those things can do it. You're gonna have to describe it better & do some checking. Unless you just want to throw parts at it until it works...
Does the ventilation fan actually blow air (whatever temperature)? If so, the fan's OK.
Does the temperature gauge come up to just under 1/2 & stay there while you drive? If so, it sounds like the thermostat is OK.
Does the AC compressor clutch engage like it should? Is the temperature control dial disconnected from whatever mechanism is behind it? (I don't have a '94 so kinda vague...)
Old Jun 20, 2005 | 02:52 PM
SloCrxDx91's Avatar
Yes, the fan does blow. Yeah, the temp gauge stays just under 1/2........It seems like the air doesn't blow that hard. I really don't no how to describe it better.
Thanks for the help
Old Jun 20, 2005 | 03:09 PM
hondaracin24's Avatar
Default Re: (SloCrxDx91)
Ive been havin the same problem with mine as well and would like to know as well...
bishop1080
Honda Civic (2001 - 2005)
Feb 5, 2010 06:25 PM
Tricid
Jun 28, 2006 07:36 PM
gsrcivic619
Mar 22, 2006 11:52 PM
DrewDown
Aug 23, 2005 12:56 PM
tianporn
Jun 18, 2005 07:22 PM
