What Greddy Blue Box do I have?
Old Jun 19, 2005 | 04:35 PM
ev0luti0n's Avatar
Default What Greddy Blue Box do I have?
I recently bought a used Greddy Turbo Kit off a fellow honda-tech member for the bseries. Problem is neither I or the seller know what application si the blue box for. Is there anyway i can find out by inspecting it to find out what application its for? gsr.. ls.. si etc etc.
Old Jun 19, 2005 | 05:26 PM
ev0luti0n's Avatar
Default Re: What Greddy Blue Box do I have? (ev0luti0n)
So what i've read is its a preprogrammed ECU that just reads the MAP sensor to see how much boost is being run to find out how much more fuel needs to be drawn. So I'm assuming that all the Blue Box come preprogrammed the same way and can be used on any honda. Can anyone tell me other wise?
Old Jun 19, 2005 | 06:55 PM
turbodohcsi's Avatar
your right about how it works, hell a friend of mine almost got one to work on a turboed ptcruiser. but for identifying it... there should be a white label on it (maybe on the side) and it will have what kinda car it goes to in the model number, like if its for a dc2, then dc2 will be somewhere in that number
Old Jun 19, 2005 | 07:01 PM
Si Shane's Avatar
Default Re: (turbodohcsi)
a map that runs at 10.5 to 1 on a b16 should be fine on a b18c1.
As long as you have a wideband, you will know whats up. All it does is add fuel, so you'll either be just right or too rich. So try it out.
Old Jun 20, 2005 | 09:31 PM
ev0luti0n's Avatar
i hope so bump for some more info.
Old Jun 20, 2005 | 10:17 PM
Si Shane's Avatar
Default Re: (ev0luti0n)
honestly, all it does is adjust fuel. It adds fuel based on MAP reading. So you'll have stock ecu + extra fuel/lb of boost. Soon as it sees around 14iunches it will drop afr to around 10.5-11:1. So if your on the worst setup, b16 box on b18, the 10.5-11:1 should be a more manegeable AFR. I can't imagine the setup would be that different, its just a super fat fuel curve.
As long as you have a wideband, you will be OK
EX-T
Mar 29, 2006 12:45 PM
E-spec Tuner
Jul 21, 2003 06:53 AM
MachAF
Jun 11, 2003 11:26 AM
dynamic696
Jul 28, 2002 10:10 AM
