any1 make their own i/c pipes??
Old Jun 19, 2005 | 02:49 PM
AlxSiR7's Avatar
Default any1 make their own i/c pipes??
i found a site claiming you can make your own i/c pipes for $70.. not bad! anyone do it successfully?? or should i just pay the $240 and buy a kit on here w/no couplers or clamps??
[$70] Charge Pipes
Where to get: http://www.jcwhitney.com
Here are the parts # that you will need!
Pipe #8 & #6: (You will need to order two of these) 81ZX3031U 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=12", (C)=5", ID=2-3/8", OD=2-1/2" Each 13.95
Pipe #5: 81ZX2953P 90 Degree Mandrel-Bent Aluminized Tubing, (A/B)=10", (C)=5", ID=2-3/8", OD=2-1/2" Each 9.95
Pipe #9: 81ZX3035N 180 Degree Mandrel-Bent Aluminized Tubing, (A/B)=24", (C)=5", ID=2-3/8", OD=2-1/2" Each 22.95
Old Jun 19, 2005 | 02:55 PM
dc2legend's Avatar
Default Re: any1 make their own i/c pipes?? (AlxSiR7)
As long as you can access a welder, do it. Pipe is pipe, just take your time and make it fit right. Good Luck
5litereater's Avatar
i make all my own piping...ic, d/p, exhaust. i pay about 50 in materials for charge piping. i fit everything up myself, cut the pieces to spec and then tack weld them. i have a boilermaler TIG weld everything for me. in the end i only pay around 80 bucks.
Old Jun 19, 2005 | 03:00 PM
BlueShadow's Avatar
Yah, if you have your own welder that can weld aluminum then other then piping costs all you are paying for is welding gas and the aluminum feed wire. If you pay a welding shop to weld it up for you then it will probably cost you another $50-$100, depending on how much the shop charges.
Old Jun 19, 2005 | 03:08 PM
nota-eg's Avatar
Default Re: any1 make their own i/c pipes?? (BlueShadow)
If you can't weld, or don't have access to a welder you may have friends that do. Me being in the redneck capitol of the world I have tons of friends that have welding machienes.
For me I'm just going to go to one of the hardware stores and buy 2.5" tubing and use couplers to hold everything together. Going to notch all the pipes using a dremel, then hairspray to make everything sticky and hold better.
Old Jun 19, 2005 | 03:27 PM
braintree's Avatar
I made my own pipes. Here's a tip, buy the bends and trace the bends on cardboard paper ( I used an old carboard box that I flattened out). That way, you cut the paper first and then use that as a template for the actual pipes. It'll save alot of time.
Old Jun 19, 2005 | 03:48 PM
AlxSiR7's Avatar
Default Re: any1 make their own i/c pipes?? (braintree)
thanks guys.. if anyone lives around delaware & wants to help me out it would be appreciated. i dont know many people who can weld!
Old Jun 19, 2005 | 04:30 PM
dc2legend's Avatar
My friend used some pvc he had laying around from work. He mocked the pipes up with those then had his **** welded to match.
Old Jun 19, 2005 | 05:12 PM
DragSource's Avatar
PVC = not the best material for your IC piping.
Just get some(4 or 5) cheap *** 2.5" U bends and do the damn thing. You can mock them up with coat hangers. . .
Did my first set with a buddy, and a sawz-all (at 1 am in my old apartments garage)
Even if you don't have access to a free welder,
it's still cheaper to buy and cut your IC piping and just take it somewhere for welding. (most places charge by the hour)
Old Jun 19, 2005 | 05:37 PM
dc2legend's Avatar
Default Re: any1 make their own i/c pipes?? (dc2legend)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2legend &raquo;</TD></TR><TR><TD CLASS="quote">My friend used some pvc he had laying around from work. He mocked the pipes up with those then had his **** welded to match.</TD></TR></TABLE>
Reading&gt; you
Old Jun 19, 2005 | 06:04 PM
nota-eg's Avatar
Do you have to get the pipes welded or can you just use couplers?
Old Jun 19, 2005 | 06:21 PM
civiccpedx's Avatar
Default Re: any1 make their own i/c pipes?? (nota-eg)
you can use the cuplers, some people have problems with them if they are running high psi, but if your under 10 i think you should be fine with couplers
Old Jun 19, 2005 | 06:24 PM
adseguy's Avatar
$70 - 4 2.5" ubends
$7 - sawzall 24TPI cutting blades
$10 - muffler shop fee to weld it all
As you can see my DP was made the same way. All I did was take the ubend and just kind of try to fit it where it should go. Then I marked and cut. I went back and tried to fit again, if it needed more cutting, I would cut again. Then I marked where they needed to be lined up for welding. I got a Downpipe and all my IC pipes finished for a total cost under $120 I believe. That's with flanges and 02 bung and EVERYTHING
Old Jun 19, 2005 | 06:42 PM
deftones0817's Avatar
Default Re: any1 make their own i/c pipes?? (adseguy)
we can help u with that as well. Let me know what you need man and we can work with you.
Old Jun 19, 2005 | 07:16 PM
projectTeG's Avatar
does it matter is the pipes are steel or aluminum? ,,,i know a noob question, but i thought that maybe aluminum would be better for the heat soak
Old Jun 19, 2005 | 07:18 PM
scartail's Avatar
if you have a cai.. u can get buy with 2 U's and a 90 deg bend. I was able to do this.
Old Jun 19, 2005 | 07:56 PM
adseguy's Avatar
Default Re: (projectTeG)
for heat properties Al. is better, but it's the cost that steers most people away
Old Jun 19, 2005 | 08:19 PM
EnzoSpeed's Avatar
Default Re: (adseguy)
I went with steel because it's easier to weld.
Got the kit from tunertoys for $87.
Old Jun 20, 2005 | 05:45 PM
T4eg's Avatar
Default Re: (EnzoSpeed)
i went with aluminum the 3" charge pipes for turbo car and the intake for the NA car cost $145. And i welded everything up
Old Jun 20, 2005 | 06:37 PM
2point2's Avatar
I made my own aluminum pipe without a welder... I only have a small bandsaw.
I just taped (2" masking tape) the pipes together and used a razor blade to cut out sections to be tacked. The guy who welded it for me didn't have to do any thinking at all..
pipes fit absolutely perfect I'll take some pics when i do the hot side and post them up in the weld/fab section.
adambomb93
May 6, 2015 04:01 AM
teddy_dc2
Mar 20, 2007 08:45 PM
hondaapi
Welding / Fabrication
Jul 4, 2006 08:21 PM
EK FLY
31
Aug 23, 2005 06:50 PM
Etylorcen
Mar 20, 2002 11:20 AM
