Car wont start, nothing works like battery is dead but really isnt. (Weird) Read on..
Old Jun 19, 2005 | 09:09 AM
E36 Guy's Avatar
Default Car wont start, nothing works like battery is dead but really isnt. (Weird) Read on..
Ok so I park and turn off my car today to run into work for a quick 5 minutes to get something. I come back to my car and try to start it...nothing works like theres no battery or something. I decide to try and pop start the car and it works.
So I drive around a little and turn it off and try to start it again. Same thing happens, I turn the key and nothing happens. No gauge cluster lights, no fuel pump primeing, nothing.
So I pop the hood and wiggle the battery wires and ground wires while pressing the arm and unarm buttons on my alarm. Eventually I hear a "beep" from my alarm. So Im thinking something must have been lose. I get back in my car and turn the key to accessory. CD player turns on, fuel pump primes, all is normal. I try and start the car. Nothing. THEN when I try to put it in accessory, nothing works now! I repeated popping the hood and wiggling the wires, got the alarm beeping, tryed again, exact same thing happend. Anyone have any idea what the deuce is going on?? ANY help is greatly apriciated.
Old Jun 19, 2005 | 09:35 AM
Orangecivic251's Avatar
Default Re: Car wont start, nothing works like battery is dead but really isnt. (Weird) Read on.. (WHACK EG4
well is your alarm hooked to disable the car to me could be short in wrirng but could be bad alarm brain
Old Jun 19, 2005 | 10:50 AM
sceg's Avatar
i had a similar problem with mine once after i replaced the battery terminals. basically the new terminals were painted where the cables made contact, hence bad connection. scraped the paint away and worked fine. funny thing was that the terminals were on for 3-4 days with no problems before this happened.
if you have access to a digital multimeter, use it to check resistance and continuity where the cables touch the terminals, and the terminals to the battery
Old Jun 19, 2005 | 10:51 AM
nocturnaldragon's Avatar
Nah I'd doubt that. Take off the battery terminals and clean them down good, replace them if they seem loose or worn, then check the oposite end of the ground going to the frame clean that too if need be and tighten it, clean it if its loose. Same thing for the positive going to the fuse box.
Should take car of it right away. If not him me up I'll help you out some more.
Old Jun 19, 2005 | 10:56 AM
E36 Guy's Avatar
Awesome thanks guys. Ill check it out.
No one thinks my alarm is ******* up and causing the problem??
Old Jun 19, 2005 | 12:53 PM
E36 Guy's Avatar
bumppppp
gwegcivic
Audio / Security / Video
24
Mar 25, 2013 02:25 PM
carlosp38
Sep 28, 2008 09:49 PM
SlammedDC2
Nov 2, 2005 01:44 PM
eg u y
11
Mar 11, 2005 01:58 AM
