car smoke at idle....
Old Jun 18, 2005 | 10:23 PM
hondaeg8's Avatar
Default car smoke at idle....
i just recently got my motor rebuilt with new bearings, pistons, rings. etc....
i have about 275 miles on the motor so far using ND 30w oil.
i notice that my car puffs out some smoke when i'm at idle sometimes... any reason why?
Old Jun 18, 2005 | 10:28 PM
dot this Promo's Avatar
Default Re: car smoke at idle.... (hondaeg8)
just break it in first. i've seen 4 motor built at RedStar and smoke comes out for the first 500 miles. but if it still does bring that back homie.
Old Jun 18, 2005 | 10:31 PM
hondaeg8's Avatar
Default Re: car smoke at idle.... (.jsb18b)
yeah.. i'm still breaking it in.. don't have much miles on it as of now.
compression test is about 210 across ....
i was thinking maybe my pvc valve went bad, i don't know.
just wondering why it would puff out small amounts of smoke at idle sometimes.
its not all the time , but it does do it.
Old Jun 21, 2005 | 04:38 PM
hondaeg8's Avatar
seems to do it after driving for a little while.
how do you check the pcv valve
Old Jun 21, 2005 | 04:43 PM
d15bcoupe's Avatar
your engine isnt going to seal perfectly until its broken in. give it time, dont worry about it unless it gets worse
Old Jun 21, 2005 | 04:53 PM
hondaeg8's Avatar
my friend told me that there are some oil spots in my intake manifold ...
Old Jun 21, 2005 | 09:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">seems to do it after driving for a little while.
how do you check the pcv valve</TD></TR></TABLE>
check if its clogged or not. replace if is. shoot some carb cleaner into if its all nasty.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d15bcoupe &raquo;</TD></TR><TR><TD CLASS="quote">your engine isnt going to seal perfectly until its broken in. give it time, dont worry about it unless it gets worse</TD></TR></TABLE>
Old Jun 21, 2005 | 10:43 PM
Jimmy's Avatar
Global Moderator
Could be valve seals..allowing oil to leak down into the combustion chamber and then on start up/idle it's burning out, but i don't see how this could be possible if you just had a rebuild.
Old Jun 21, 2005 | 10:55 PM
hondaeg8's Avatar
yeah.. pcv valve is dirty
friend told me sometimes my car smokes while i shift or let off gas...
i guess i just need to put more miles on the motor, but i thought the rings would have seated by now with 275 miles on the motor.
Old Jun 21, 2005 | 11:01 PM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaeg8 &raquo;</TD></TR><TR><TD CLASS="quote">yeah.. pcv valve is dirty
i guess i just need to put more miles on the motor, but i thought the rings would have seated by now with 275 miles on the motor. </TD></TR></TABLE>
Change your 2.00 pvc valve then, if that doesn't work then it sounds like valve seals.. Perfect symptoms (smoke when let off gas, smoke on idle)
Old Jun 21, 2005 | 11:17 PM
hondaeg8's Avatar
where do i get the pcv valve?
i check it and if you blow on it on one side, you can feel the air come out the other side. if you blow in it on the other side, air won't go through.
also, the pcv valve hose that goes from the pvc valve to the intake manifold wasn't all that good. it would get liked crimped when the car was on cause it seems like the hose is week. if you squeeze the hose where it look like it was getting crimped, you can feel more air going through it... don't know if thats understandable or not.
one slow coupe
Jul 3, 2010 11:28 AM
prettylew
45
Dec 16, 2007 06:48 PM
platinum00
Jan 2, 2006 04:23 PM
FAST94GSR
Dec 15, 2001 05:07 PM
