how much whp can I get w/ this set-up?
I am thinking about running this set-up and I was wondering what kind of power I can make after getting a dyno tune.thanks.
crower 403
crower valvesprings
crower ti. retainers
CAI/H/E
P30pistons
new piston rings
skunk2 IM
exedy stage1 clutch
xact flywheel.
and I would most likely use a piggyback such as SAFC.
crower 403
crower valvesprings
CAI/H/E
P30pistons
new piston rings
skunk2 IM
exedy stage1 clutch
xact flywheel.
Yeah, you need to get hondata...
We cant tell you how much whp its going to make because nobody really knows, unless someone has the same exact setup, but then the tuning is still going to vary. All you can do is wait until you get it tuned and find out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Peezy Fo Sheezy Neezy »</TD></TR><TR><TD CLASS="quote">I want to run a similar setup, would I have to have the block Sleeved?</TD></TR></TABLE>
no..you wouldnt have to..if you wanted to go to 84 or 85mm than youd need to get sleeved...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickgmiller0408 »</TD></TR><TR><TD CLASS="quote">
no..you wouldnt have to..if you wanted to go to 84 or 85mm than youd need to get sleeved...</TD></TR></TABLE>
Its anything above 81.5
this is just an idea, but check it out maybe there is something in here that can help you.
http://www.importreview.com/d_1.8.html
