C&R or Koyo Radiator?
I gotta get a new radiator for my car, seeing as how my old one was stolen. I went the the Acura Dealership to ask them how much it was, and they said it was $484 for just the Radiator... so I figure it'd be better to just get an aftermarket one.
So I was just wondering which one would be a better buy? And also which one will fit in my ITR, Denso or Showa. Also, what is the difference between all aluminum and aluminum/plastic, since there seems to be a great price difference. I will also be running my car NA, no turbo. And if it's not too much trouble, a few links to some places with good prices would be greatly appreciated.
Thanks. -.^''
Thanks. -.^''
Denso is USDM and Showa is JDM. Get the one that matches your front end. I believe the Showa model is a little thicker.
A few of my friends run Koyo's and they have no problems at all. I've heard recently that the filler neck is a little weak
. The C&R comes with a fan and is also of great quality. A little pricey though.
There are a few sponsors in the Performance Section selling Koyo's. I'll probably get one when the time comes.
Hope this helps
. The C&R comes with a fan and is also of great quality. A little pricey though.There are a few sponsors in the Performance Section selling Koyo's. I'll probably get one when the time comes.
Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hooch’n »</TD></TR><TR><TD CLASS="quote">how much does your Temp drop vs. a stock unit?</TD></TR></TABLE>
unless you change the the thermostat, none at all
RJ - who would just get a stock replacement from radiators.com or the parts store and save a bunch of coin
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR-00-1457 »</TD></TR><TR><TD CLASS="quote">I have a C&R and I love it, it keeps the engine temps down even on real hot days. definately worth the $$$</TD></TR></TABLE>
So would a stock radiator.
I never had a temp issue with the stock radiator, a/c installed, running hard at the track in 100 deg temps in my ITR.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ »</TD></TR><TR><TD CLASS="quote">
I never had a temp issue with the stock radiator, a/c installed, running hard at the track in 100 deg temps in my ITR.</TD></TR></TABLE>
wish i had a oil cooler though
RJ - who would just get a stock replacement from radiators.com or the parts store and save a bunch of coin</TD></TR></TABLE>
or - if you have the coin(s), either of the 3 (stock, C&R, Koyo) with a new thermostat would be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Girl »</TD></TR><TR><TD CLASS="quote">Also, what is the difference between all aluminum and aluminum/plastic, since there seems to be a great price difference.
Thanks. -.^''</TD></TR></TABLE>
In the honda's I've owned the plastic/alum ones tend to crack where the 2 materials meet. This has happened to every honda I've owned. If you can get an all aluminum one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01PY0559 »</TD></TR><TR><TD CLASS="quote">
In the honda's I've owned the plastic/alum ones tend to crack where the 2 materials meet. This has happened to every honda I've owned. If you can get an all aluminum one.</TD></TR></TABLE>
thats what happened to me too....so i just got the c&r. came with 1 big fan which kept the temps down if i did not use a/c. the temp needle kept on going up while sitting in SoCal traffic with a/c so i bought a tiny 8" fan and i havent had a problem since.
