B20b/z question, I've searched to no avail...
Old Jun 18, 2005 | 04:47 PM
zerovandez's Avatar
Default B20b/z question, I've searched to no avail...
Plain and simple, I just want to put a B20b/z in my vehicle. Whats required? Links? And i'd like to strengthen the sleeves as I hear they're weak, what or who makes the sleeves?
Old Jun 18, 2005 | 04:52 PM
Absubtle's Avatar
just wondering
Absubtle
PA
Old Jun 18, 2005 | 04:57 PM
BlueIntegraBoy's Avatar
Default Re: B20b/z question, I've searched to no avail... (zerovandez)
A B20 swap is like any other B-series swap.
Old Jun 18, 2005 | 05:11 PM
1.8turbolsvtec's Avatar
swap the intake manifold to a ls and are you going to boosted it others wise the sleves are ok
trans axles ls ecu ls intake manifold shift linkage mounts
Old Jun 19, 2005 | 05:39 PM
zerovandez's Avatar
Another question, If I wanted to replace clutch and flywheel, would it be the same as purchasing any flywheel for any B series? Or does this have to be model specific?
Old Jun 19, 2005 | 08:21 PM
zerovandez's Avatar
Default Re: (zerovandez)
bump, i'd really like to know.
Old Jun 19, 2005 | 08:59 PM
Luserkid's Avatar
Order parts for an LS thats basically what the motor is but alot bigger.
You need the intake manifold and tranny.
Old Jun 27, 2005 | 03:23 PM
zerovandez's Avatar
what radiator hose would I use?
Old Jul 7, 2005 | 07:51 PM
Absubtle's Avatar
If I get you correct u just want to swap the B20 unmolested in your teg...correct? The rad hose should be used from the chassis that engine came out of.. But the B20 should be damn close to that of the B18a/b engines. Only reason you'll need an intake, is because the intake on the B20 in CRV's are very vertical and probably wouldnt fit under your hood line. The trany needs swapped cause of AWD tranny that would come w/ the B20 from the CRV.
Darton makes sleeves for the B20. Golden Eagle makes stuff fof that engine also.
Absubtle
PA
Absubtle
Pa
1994delsolLS
14
Jan 6, 2025 10:55 AM
REDekSI
Aug 16, 2007 04:39 PM
B20_EG8
May 3, 2007 01:22 PM
redDAinteg
Oct 18, 2006 10:29 AM
90lsteg
Apr 8, 2005 03:40 AM
