PROBLEM WITH MY 93 CIVIC VX!!!!
Old Jun 18, 2005 | 01:59 PM
lil_jess's Avatar
Default PROBLEM WITH MY 93 CIVIC VX!!!!
My car will run but motor shake! I thought it was motor mount, axle, vacuum hoses, air sensor, iac sensor, fuel pumps hose, clutch cylinders, all fuses, battery and etc. All of these has been checked and replaced to new and its cleared!!! What else could it be!!! It has a engine check lights come on. I test it and it show me three flash with its is the iac, but if you look closer it has six little flash that you can't bearely see it. What does this mean!!! Someone told me that it is timing belts, distributer, spark plugs & wires that is doing it!!!! Please let me know whats up because i needed the car for works commuting!!!
Old Jun 18, 2005 | 02:01 PM
Kyles ej1's Avatar
Default Re: PROBLEM WITH MY 93 CIVIC VX!!!! (lil_jess)
so what the **** are u trying to ask? u sound like your from the south and wrestle with pigs all day and dont know how to speak
Jorsher's Avatar
Sounds like it's just idling rough. Try cleaning the IAC? Here's a link I found, you should bookmark stuff like this while reading around for future reference
http://www.g2ic.com/forums/sho...35534
Eh, and he lives in CA, might be mexican or somethin. Chill.
Old Jun 18, 2005 | 02:03 PM
lil_jess's Avatar
Default Re: PROBLEM WITH MY 93 CIVIC VX!!!! (93ejay1)
if you will look closer and used your eyes to look closer and read if you know how then you'll know what i'm talking about!!!! B_J!!!!
Old Jun 18, 2005 | 02:06 PM
lil_jess's Avatar
Default Re: (Jorsher)
hey i have a uncle who came yesterday and checked the car. He pull out the spark plugs wire and their was no spark then to the next one. Suddenly it just the car just die out!! I went to the junk and got a si distributer, bought brande new spark plugs wire , and spark plugs. But i forgot how the spark plugs wire is setup. It will start choking!!!
Old Jun 18, 2005 | 02:12 PM
Jorsher's Avatar
Default Re: (lil_jess)
You will need to do this...
1. Put in the spark plugs (make sure you torque to proper specs)
2. Put on the dizzy.
3. Put on the wires, firing order I'm pretty sure is 1-3-4-2. With cylinder one being farthest from the dizzy.
4. Set the timing. It might run but that's because the ECU can adjust so it'll run, be sure to set the timing correctly..
Old Jun 18, 2005 | 02:26 PM
lil_jess's Avatar
kool! i will go and do what is necessary!!
LudeToAHatch
65
Apr 23, 2015 02:41 PM
hondabinge
16
Aug 23, 2013 01:21 PM
724chris
10
Dec 17, 2009 07:21 PM
01ITR#700
Apr 10, 2008 11:20 AM
Si4WS
Jul 29, 2002 10:03 PM
