Spark problem?
Old Jul 29, 2002 | 10:34 AM
Si4WS's Avatar
Default Spark problem?
My wife has a 93 Accord SE and it has a missing problem. The car feels like it has a fouled plug or something. I changed the plugs, cap, and wires and cleaned the rotor and the problem is still there. It happens at idle and under acceleration. We just bought the car. What should I check next? Only other thing I can think of is a fuel filter. The car has the f22a6
Old Jul 29, 2002 | 10:42 AM
Ideal's Avatar
Default Re: Spark problem? (Si4WS)
you did properly space the spark plugs, right?
Old Jul 29, 2002 | 11:47 AM
Mikey3000's Avatar
what about the ignitor? i bet that's it.
Old Jul 29, 2002 | 12:00 PM
Audi2Honda's Avatar
Check for Vacumm leaks. Get a can of starter fluid and spray the mist around the engine bay at the rubber hoses a little at a time with the motor running. If the engine suddenly revs higher then you have a vac. leak. It will rev because a crack in a hose is sucking in the starter fluid which is highly potent stuff and will cause engine to run faster briefly.
If thats not it you could also have a warped or cracked intake manifold. 02 sensor could be bad sending false data to the ECU and causing the air/fuel mixture to be off also.
Old Jul 29, 2002 | 12:19 PM
Larry Bastanza's Avatar
Before you go changing a whole bunch of parts, you need to understand the condition of the engine. Do a compression test FIRST. Go on from there.
Good Luck,
LarryB
Old Jul 29, 2002 | 01:52 PM
Chiovnidca's Avatar
Default Re: Spark problem? (Larry Bastanza)
Old Jul 29, 2002 | 05:28 PM
Si4WS's Avatar
Oh yeah, no CEL either. I did check the gap on the plugs, I'm taking it to a shop tomorrow to get fixed if I can't figure it out tonight.
Old Jul 29, 2002 | 10:03 PM
Si4WS's Avatar
Also, missing goes away about %90 when warmed up and driving. Idle is still bad.
Kannan08
16
Oct 30, 2011 07:58 AM
egGSR_hi
May 16, 2009 12:23 PM
93b20z
Apr 6, 2005 04:15 PM
95AccordGuy
Jul 16, 2004 02:54 AM
sajm
Dec 18, 2002 07:10 AM
