just a couple simple ?s for someone looking into a type r motor
what is the engine code for the type r motor?
is there a vtec type r?
is there a way to make any of the other integra motors vtecs?
please don't get upset at this post. i just figured this was the best forum to post this in to get the quickest response. thanks.
typeR only comes with VTEC engine.
LS-VTEC can be achieved with LS bottom end + VTEC head + etc.
Actually B18C is for JDM and I think the euro spec is B18c6.
The CRV B20 engine can also be "converted" to VTEC.
thanks for the info. do they make a type r motor for pre 95? i want to stick with obdI wiring for the swap. also, can the gsr motor be converted to vtec? do the heads swap over from the type r to the gsr?
They don't make Type R engines for pre 95's. 96 was the first year in Japan.
GSR engines already have VTEC, but the Type R heads will switch over to a GSR block with no modifications.
ya gsr motors are DOHC VTEC for 94-95. I guess if u want to avoid OBDII the only way would be to convert the wiring and pick up an OBDI ecu..its good in a sense, cuz it gives u an excuse to buy a Hondata lol.
[Modified by SpoonCivic, 4:23 PM 2/12/2002]
Also, if u wanna avoid OBDII wiring, i think it would be better to pick up a JDM B18C-R motor, since they do not have OBDII. (or atleast this is my impression).
crxplus - Maybe you should browse http://www.vtec.net to get more information.
All the basics are covered there.
AREJAY
Sep 5, 2004 09:09 PM
4wsB21a
Feb 12, 2002 07:47 AM
