200K miles and 200+ psi compression test? d16z6
Old Jun 18, 2005 | 06:40 AM
stealth89hatch's Avatar
Default 200K miles and 200+ psi compression test? d16z6
i just did a compression test with my autozone compression gauge for the first time on my 92 si and the results were 209 209 211 213. i did seafoam regular and deep creep in an attempt to clean out any carbon build up that may have been keeping the compression high. the results afterwards were about 1psi lower across the board.
it seems really high for, well, any motor.
whats the deal?
i've used the guage one other time on another motor and it scored like 185 avg. i think.
Old Jun 18, 2005 | 06:49 AM
one slow coupe's Avatar
Default Re: 200K miles and 200+ psi compression test? d16z6 (stealth89hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth89hatch &raquo;</TD></TR><TR><TD CLASS="quote">i just did a compression test with my autozone compression gauge for the first time on my 92 si and the results were 209 209 211 213. i did seafoam regular and deep creep in an attempt to clean out any carbon build up that may have been keeping the compression high. the results afterwards were about 1psi lower across the board.
whats the deal?
i've used the guage one other time on another motor and it scored like 185 avg. i think.</TD></TR></TABLE>
I did one on my 99 si with 95,000 miles and my numbers were like 205,215,215,210..
I guess your car has just been taken care of
Old Jun 18, 2005 | 06:57 AM
Aphelion's Avatar
way to go man :D those numbers are great... now turbo it :D
Old Jun 18, 2005 | 07:10 AM
ha thats the plan.
then blow it up,
then build the block
Old Jun 18, 2005 | 07:30 AM
Dwight Schrute's Avatar
Default Re: (stealth89hatch)
i would just get a new block to build while you boost this one... d-series are so cheap anyway
Old Jun 18, 2005 | 08:11 AM
komat's Avatar
Default Re: (drewthomas14)
is that a stock z6??
seems a little high for a a stocker
Old Jun 18, 2005 | 09:12 AM
hatch34's Avatar
Default Re: (komat)
damn those are some great numbers
Old Jun 18, 2005 | 10:44 AM
ABK's Avatar
ABK
Default Re: (hatch34)
yeah that's little bit too high
EDIT: are you sure that the head wasn't milled, or block wasn't decked. Try to seafoam it over night.
Modified by ABK at 8:41 PM 6/18/2005
Old Jun 18, 2005 | 11:13 AM
swifty4u's Avatar
Default Re: (ABK)
Yep shouldnt it be around 185?
Old Jun 18, 2005 | 12:34 PM
Nyceguy17's Avatar
Default Re: (swifty4u)
I don't wanna sound insulting, but you DID unplug the distrubutor from the harness while you did the test, right?
Old Jun 18, 2005 | 04:11 PM
Cripsaks808's Avatar
I had a D16a6 stock block head milled .002 and it compression checked at 235 all even with the cam gear retarded 2 degrees. Dont seafoam it just let it go, carbon build up is your friend as long as it doesnt make your car "diesel"
Old Jun 18, 2005 | 08:52 PM
to my knowledge the motor internals are all stock. i dont know if its been milled, but neither me nor the previous owner have owned it that long.
i didnt unplug the dizzy harness (because the wires are hidden and their a bitch to get out) but i took all the spark plug wires totally off (and took all spark plugs out, unpluged all injectors) while i was doing the test. is there a difference between that and unpluging the dizzy and leaving the 3 other spark plugs in while you try the 4th one?
Old Jun 18, 2005 | 11:05 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stealth89hatch &raquo;</TD></TR><TR><TD CLASS="quote">to my knowledge the motor internals are all stock. i dont know if its been milled, but neither me nor the previous owner have owned it that long.
i didnt unplug the dizzy harness (because the wires are hidden and their a bitch to get out) but i took all the spark plug wires totally off (and took all spark plugs out, unpluged all injectors) while i was doing the test. is there a difference between that and unpluging the dizzy and leaving the 3 other spark plugs in while you try the 4th one?</TD></TR></TABLE>
It's just safer to unplug the dizzy.
Old Jun 18, 2005 | 11:21 PM
Morning Call's Avatar
id be happy for that compression
Old Jun 18, 2005 | 11:33 PM
Bond's Avatar
Default Re: (Morning Call)
^^^^ You have replied after me the whole night. Kinda creepy....j/k.
Old Jun 18, 2005 | 11:45 PM
Nyceguy17's Avatar
You can do 1 plug at a time, but it will noy read accurate with the dizzy plugged up.
Old Jun 19, 2005 | 10:37 AM
blackeg's Avatar
Default Re: (Nyceguy17)
the #s are sweet. my z6 had 143,xxx on it when i did my last pressure check. came back between 205-210 psi per cyl. its probably just got a little carbon in it, no big deal.
88 civic
Apr 5, 2009 03:21 PM
self_made
Jun 19, 2005 12:36 PM
snowblind7x
Apr 13, 2005 08:12 PM
sdinteg
Feb 1, 2005 07:52 PM
