How to install a clutch on my 95 Civic 1.5L SOHC
Old Jun 17, 2005 | 09:52 PM
Eq_Coupe2k's Avatar
Default How to install a clutch on my 95 Civic 1.5L SOHC
Need Help never did this before. Your Fellow Member:Eq_Coupe2k
Old Jun 18, 2005 | 01:22 PM
Used2beAb16's Avatar
Default Re: How to install a clutch on my 95 Civic 1.5L SOHC (Eq_Coupe2k)
get a helms manual it will be beneficial.
Old Jun 18, 2005 | 01:28 PM
komat's Avatar
Default Re: How to install a clutch on my 95 Civic 1.5L SOHC (Used2beAb16)
http://www.c-speedracing.com/h...h.php
Old Jun 18, 2005 | 02:25 PM
Deemeetree's Avatar
Electrician
Drain fluid.
Remove axles.
Remove transmission.
Change out clutch and flywheel.
Sounds easy huh?
You better get a Helms.
Old Jun 18, 2005 | 06:48 PM
Insane Beast's Avatar
Default Re: (Deemeetree)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deemeetree &raquo;</TD></TR><TR><TD CLASS="quote">Drain fluid.
Remove axles.
Sounds easy huh?
You better get a Helms.</TD></TR></TABLE>
EG-tofu
Mar 8, 2007 09:00 PM
ApolloSpeed
28
Feb 11, 2006 08:01 PM
is3oo
Nov 1, 2003 08:51 PM
hunterln
Sep 18, 2001 10:08 AM
Mr. Vapor
Aug 27, 2001 04:00 PM
