Blockguard question
Old Jun 17, 2005 | 06:23 PM
LSVtecHatchback's Avatar
Default Blockguard question
I have a STR blockguard in a LS/Vtec swap. Is it suppose to be even with the surface or 3-5mm down?
Old Jun 17, 2005 | 06:37 PM
slomofo's Avatar
GDD Member
I think you're supposed to drill out the waterjackets, press it in, then deck your block. Not sure though, as I've never wasted money on such a thing.
Old Jun 17, 2005 | 07:31 PM
snowseeker's Avatar
Default Re: Blockguard question (LSVtecHatchback)
My last motor I tapped the block guard in after much time grinding down the posts on the block guard to make it fit just right. I put it down around 5mm from the deck.
My new motor I did a flush mount and welded it in. Just check if the holes in the block guard line up with the head gasket good. If they don't sink it down a little in the block.
Do not pound it in with much force at all! Will egg out the cylinders. Should just tap in lightly.
TGonie
Welding / Fabrication
Aug 3, 2013 02:05 PM
10SecDSM
Sep 15, 2006 08:11 AM
b00stedbyFastrax
Sep 27, 2002 01:14 PM
EFing8
Jan 27, 2002 01:20 PM
