car wont start!!!
Old Jun 17, 2005 | 01:06 PM
WhiteGSR95's Avatar
Default car wont start!!!
so i got up this morning and as i was leaving to school the god damn car wouldent start.
the engine cranked so the starter, and batt are ok. i even took out my dmm to make sure it was at the correct voltage. i think that its gonna be my distributor. when i would get to about 5krpm the needle would jump way past 9k ive been assuming that it was the dizzy doing this.
Old Jun 17, 2005 | 01:18 PM
WhiteGSR95's Avatar
tf i just went to my car, it turned on then died after about 5 seconds, then i turned it on again and it was like normal. i turned the car off for a min turned it back on and it started up again. WTF.
i know that its not a bad fuel filter. its only like 3 months old.
Old Jun 17, 2005 | 01:31 PM
projectTeG's Avatar
check your ingnitor, grounds, and main fuel relay,...do you here the click or the cel going off?
Old Jun 17, 2005 | 01:39 PM
WhiteGSR95's Avatar
ignitor is about 3-4 months old. grounds r good, and ill check the relay in abit.
no cels
Old Jun 17, 2005 | 01:46 PM
projectTeG's Avatar
yea where you put the ignition switch to the on position without stating it...you should see the CEL come one and when it goes off you sould hear a click
Old Jun 17, 2005 | 05:48 PM
WhiteGSR95's Avatar
ea its good
Old Jun 17, 2005 | 06:11 PM
full Circling's Avatar
From: That's the wrong tone... I'm Skunk2 certified.
do you know anyone that has a fuel pressure gauge? if so, that will narrow your search down quite a bit. i'm not sure what stock pressure is, though.
any backfiring or weird sounds when trying to start it?
Old Jun 17, 2005 | 06:17 PM
WhiteGSR95's Avatar
yes
Old Jun 17, 2005 | 06:21 PM
pull a wire off of a plug, put it next to something metal, and see if you get spark. if not, it's most likely your distributor.
Old Jun 17, 2005 | 06:54 PM
WhiteGSR95's Avatar
it does have spark,
Old Jun 17, 2005 | 07:17 PM
almazan85's Avatar
Default Re: (WhiteGSR95)
Hey bro, i had the same problem with my gsr 95. I am not going to say its 100 % it but what u are describing it seems to be about the same. Behind and underneath the distributor there is a ecu ground wire that is held by a ten mm screw to a bracket. Tighten that screw cause it will get loose after a while. That seemed to be it for me. Sometimes it would leave me stranded, sometimes wont get me nowhere.
Old Jun 17, 2005 | 07:35 PM
WhiteGSR95's Avatar
ill go check that right now.
the car has been running fine. i drove it 4 about 5 minutes awhile ago and i went out to just turn it on about 10 minutes ago.
Old Jun 17, 2005 | 07:48 PM
DA6Iceman's Avatar
hahahaha.. my 92 does the same thing.. I have got it down to a science, its your main relay under the dashboard. when its hot outside or the relay gets hot, when you turn the key over it doesnt allow the ignition or fuel to kick in so therefore no starting. when my car does it it will run for a few seconds then shut off, keep trying it until you hear the fuel pump turn on.I leave my relay un attatched from the mounting location so i can flick it and then it works.. this is the 3rd or 4th honda that I have had that does this and my buddies do it also so i would imagine that its common.. hope this helps you
Old Jun 17, 2005 | 08:21 PM
WhiteGSR95's Avatar
interesting
Old Jun 18, 2005 | 10:55 AM
main relays are easy to fix. just remove the cover, and resolder all the connections. the solder joints crack over time, degrading the circuit.
this doesn't address your tach jumping up to 9k though.
Old Jun 18, 2005 | 11:13 AM
WhiteGSR95's Avatar
Default Re: (^^whatnoobsearchthenGTFO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ^^whatnoobsearchthenGTFO &raquo;</TD></TR><TR><TD CLASS="quote">main relays are easy to fix. just remove the cover, and resolder all the connections. the solder joints crack over time, degrading the circuit.
this doesn't address your tach jumping up to 9k though.</TD></TR></TABLE>
yea ive been trying ti figure that **** out, only things i can think of r a possible loose wire in the distributor posibly the igniter, or the distributor is going bad
Old Jun 18, 2005 | 11:39 AM
DA6Iceman's Avatar
the tach jumping sounds like your ignition module
Old Jun 18, 2005 | 07:56 PM
WhiteGSR95's Avatar
Default Re: (DA6Iceman)
yep
Old Jun 19, 2005 | 12:50 AM
Lscivichatch92's Avatar
could be the coil or ignitor, definately sounds like ignition to me, use your dmm and check your primary and secondary resistance on your coil. if you dont know how to do that, any honda repair manual can show you. if that checks out good then test the igniter. If thats good then look at fuel but it sounds like a big ignition problem.
gsmith93
May 13, 2013 02:37 PM
drew10
Jul 16, 2010 04:01 PM
91rexhf
10
Dec 27, 2008 05:06 PM
zach1288
Nov 16, 2006 12:20 PM
coot_er
11
May 7, 2005 08:54 PM
