RODS ? WTF!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperTeg95 »</TD></TR><TR><TD CLASS="quote">it looks like you got gsr rods. </TD></TR></TABLE>
If the black one is a stock B20 rod and yours is significantly shorter it's pretty obvious you didn't get Manley LS/B20 rods, you probably got B16 rods but it seems like there's something funky going on as well. B16 rods would only put the piston a tenth down further in the hole then LS/B20 rods. Measure the deck height of your block, check out your pistons, and your crankshaft as well.
just some numbers out of the months honda tuning.
from the pic it looks like there is way more than 1mm diff.
b16a=137mm
b18a1,b20b4=137mm
b18c=138mm
b17=131.9mm
h22=143mm
h23=141.5mm
k20=139mm
k24=152mm
b16a=137mm
b18a1,b20b4=137mm
b18c=138mm
b17=131.9mm
h22=143mm
h23=141.5mm
k20=139mm
k24=152mm
That is a tall deck Dart block you are playing with. It is around 9/16" taller than the standard block, which is 211.5mm compared to your 226mm block. If you are using stock pistons and rods, you will get that result. I think Eagle makes a set of rods you can use with an ls crank to get your geometry correct.
My question to you is how did you get a tall deck Dart block and not know it?
Heres a picture for you to compare. Its a block form post earl made not to long ago.
Also, not sure whats up with the rod deal but if thats really a pr4 rod, then the manley is obviously the wrong one. When you measure rods, I think you measure from center bore to center bore.
i ordered a standard one and when it arrived i just dropped it off at the machine shop without checking anything, and when the assembly started to take place i came across that speed bump.
anyone wanna trade a tall for a ready to roll standard since im a moron.
Assuming there *is* a rod difference between the stock B20 rods and those silver rods, someone really fuct up at that place. Whats odd is that there shouldn't be a 14mm difference between a B20 rod and any other b-series rod like that shows (almost an entire wrist pin bushing [19mm] short).
I guess you should make a lot of measurements, stroke/deck/rod/wrist pin height... BTW Earl's buildup was a tall block, yours looks the same. No idea about the rod diff.
https://honda-tech.com/zerothread?id=1262775
