h23a1 diagram
Old Jun 17, 2005 | 12:21 PM
fartknocker's Avatar
Default h23a1 diagram
anyone have a h23a1 diagram im tryin to check my iacv out please help
Old Jun 17, 2005 | 12:25 PM
Qveon's Avatar
How what do you mean "Diagram" there are many types, do you need vacumm or what? If you are looking for the IACV, its on the front of the intake manifold right in the middle. It has a connector hooked up to it and has 2 hoses coming out of the bottom.
Old Jun 17, 2005 | 12:27 PM
Default Re: (Qveon)
im just trying to figure out why my car is idiling from 1 g to 2 gs and some one told me iacv
Old Jun 17, 2005 | 12:52 PM
Qveon's Avatar
Default Re: (fartknocker)
surging idle or just a high idle?
Old Jun 17, 2005 | 02:14 PM
h23a1pimp's Avatar
Default Re: (Qveon)
it is a surging idle
from 1g to 2 g constantly
Old Jun 17, 2005 | 07:06 PM
Qveon's Avatar
Default Re: (h23a1pimp)
ok well the IAC does not have any vacuum lines running to or from it.
How to test it: Take your intake off and on the bottom left side of the inside of the throttle body before the butterfly, you will see a hole. with the car running, put your finger over the hole and plug it. Your idle is going to drop, check to see if it is still surging. If it is you have a vacuum leak elsewhere, start checking hoses by pinching them to see if the surging goes away.
Old Jun 18, 2005 | 11:41 AM
h23a1pimp's Avatar
Default Re: (Qveon)
i held my finger over the hole and it started idleing fine wht should i do now???????????
Old Jun 20, 2005 | 07:21 AM
h23a1pimp's Avatar
i need help with my idiling i think it is my fitv but im not sure help me
Old Jul 18, 2012 | 10:59 PM
Harley Pace's Avatar
Default 1995 Prelude Si idle problem
I have a 1995 prelude Si with the h23a1 and I had a new engine and transmission put in an now when I start it up it idles at 5-6k any help?
luv2boost
Jun 2, 2008 06:33 PM
GSTDA9
Feb 7, 2008 03:59 PM
RiceBurninCX
Jan 24, 2008 02:02 PM
wilrock
Apr 4, 2006 05:56 PM
Teknic73
Dec 1, 2003 08:44 PM
