D16z6 running on two cylinders after rebuild.
I'm not positive if my timing belt is on the correct teeth, reguardless, if i skip it some teeth, it runs bad still, of course some teeth much worse than others. When removing the number 1 and number 2 spark plugs, the car idles up a little and runs the same, when removing 3 and 4, the car nearly dies.
Sup wit dat?
Sup wit dat?
what do you mean injectors in the right sequence- ? i have a nearly same problem are is running on 3 ! my number 3 is down and i can take the plug out and it runs the same- remove the plug and its covered with oil mixed with gas like its not burning the fuel but it is getting spark so it makes no sense
Check your firing order, number 1 is the point towards the intake manifold (Haynes said it was the buttom point), firing sequence is 1 3 4 2.
I brought my injector harness in from the passenger side insted of the driver's side, i had them installed completely backwards.
boarding2008
Apr 7, 2012 01:32 PM
stephen_civic98
Feb 23, 2010 09:50 AM
