Vacume Leak
Old Jun 16, 2005 | 07:56 PM
poopydx's Avatar
Default Vacume Leak
I have a vacume leak on my stock dx motor in my 93 hatch.....the engine is from a different hatch (a 94 dx) and they previous owner replaced all the gaskets. The motor has a vacume leak which is causing the idle to be messed up and what not. It will go from 2000 to 1500 while idling. I have had a few people look at the car, and we cant seem to find the leak...any ideas on how to stop it?
thanks
Old Jun 16, 2005 | 08:00 PM
neutron91's Avatar
Default Re: Vacume Leak (poopydx)
well you have to find it before you can stop it... leave the car running and start spraying carb cleaner around areas that can leak... the motor will starve itself when it sucks the cleaner in and usually die... then you will know where to look for the leak
Old Jun 16, 2005 | 08:01 PM
Status Sean's Avatar
Default Re: Vacume Leak (neutron91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neutron91 &raquo;</TD></TR><TR><TD CLASS="quote">well you have to find it before you can stop it... leave the car running and start spraying carb cleaner around areas that can leak... the motor will starve itself when it sucks the cleaner in and usually die... then you will know where to look for the leak</TD></TR></TABLE>
Old Jun 16, 2005 | 08:03 PM
poopydx's Avatar
so i will know where the leak is by where the engine sucks in the cleaner...sounds like a start..thanks!
Old Jun 16, 2005 | 08:27 PM
solareclipseauto's Avatar
Default Re: (poopydx)
just spray each hose individually and listen
CRXDaddy78155
Sep 4, 2006 11:42 AM
BigRonDawg
Oct 10, 2005 02:10 PM
LilCivic04
Sep 9, 2005 11:28 PM
hatchdrvr
May 4, 2003 07:05 PM
