Crank Pulley Bolt won't BUDGE!
Well, got all my parts from my local honda dealer to change out the timing belt, belt tensioner and water-pump. Not bad around 200, got home and could not get the crank pulley bolt to budge....Is this thing reverse threaded, welded or super-glued in? I weigh in around 235, I put my whole body into it and I mean feet on a full 1/2 breaker bar, back braced against the garage wall...all I did is bust my crank pulley stabilizer bar. Went at this thing for 5 that is FIVE hours did everything but torch the bolt. I read some of the posts on here regarding others and their techniques. I have the HX w..power steering pump pulley and AC Pulley ABSOLUTELY no holes in any of them not even the dampner. My bicycle chain vise grip type pulley stabilizer wrench is too small for the big pulleys, so after breaking my belt type stabilizer wrench I tried to put the chain wrench on the small outer AC pulley---my fear of the whole thing rotating on the dampner rubber was realized but the bolt didn't budge.......HELP
its regular thread lefty loosey. and yes its a bitch i broke the head off mine before it came loose. i even broke a socket exstention and knuckles craftsman too. you can take it to a shop and have them loosen it then take it home and finish the job. i think the easiest way is a 3/4 drive impact cause trust me a 1/2 impact wont do it or it wouldnt for me.
Well, I am not sure what I just saw, but let's see if I am following what you did? a) you used one breaker bar to lock up the front drivers side wheel, b) took another 3/4" breaker bar to the pulley bolt with extensions, c) put a cheater bar on the one with the extensions to the bolt....and now here is where I get a little lost, your brother stood out of the car and set the breaker bar with cheater while you were in the car and geared it up...Nah! really, that's just spooky.
Dont feel bad, your pully is toast if I read your post right, I did the same thing I ussed a big *** pipe wrench on mine braced against the shop floor. Luckily for me the pully snaped at the same time the bolt came loose.
Anyhow theres a post in my sig on how to get this bitch out, you shoulda searched before doing what you did tho, but live and learn I should of too and dident.
A new pully from the dealer is like $85 tho or you can take a chance on a ussed one, I sold one on here to somebody for $20 so thats about the going price.
Good luck!!!
Good luck!!!
no dont start the motor with the wrench on there it will spin it the wrong way and probably break the head off. he is saying he was in the car and steped on the brakes with the car in gear so the motor wouldnt turn over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">no dont start the motor with the wrench on there it will spin it the wrong way and probably break the head off. he is saying he was in the car and steped on the brakes with the car in gear so the motor wouldnt turn over.</TD></TR></TABLE>
Actually it would not spin it the wrong way. But none the less it is not a smart idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">
Actually it would not spin it the wrong way. But none the less it is not a smart idea.</TD></TR></TABLE>
think about it the motor turns counter clockwise asuming your looking at the crank bolt. now if you had your socket with breaker bar on there against the ground and the motor turning couner clockwise its gonna turn the bolt clockwise and snap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e jay one »</TD></TR><TR><TD CLASS="quote">think about it the motor turns counter clockwise .</TD></TR></TABLE>
That's funny, cuz this looks like it's spinning clockwise.
do you drive a honda? hope so if you do go out a start it then look at your belts and tell me which way they are spinning.
</TD></TR></TABLE>do you drive a honda? hope so if you do go out a start it then look at your belts and tell me which way they are spinning.
Alright let me just put an end to all the BS right now.
The only right way to do this is with the correct tool as outlined in the thread in my signiture.
Alright end of story. That should help you out even if you did damage the pully like I belive you said in your original post by damaging the vulcanized material holding the two halves toghter.
Also this is a thread about a crank pully not which way a Honda engine turns.
Most honda engines (including B's and D's) spin counter clockwise when looking from the cylinder 1 to 4.
I used a 2" breaker bar and had my friend hold the brakes with the car in gear. bolt came off with ease.....
even with impact guns sometimes they can be a bitch.
they make crank pulley holders one specifically for hondas and another one which is adjustable and has a chain to it.
downside of the chain is it might chip your pulley. i've only had to use the chain once only because 3 air guns couldnt take it off and all 3 had really high lbs or power.
Honda engines spin backwards from that of normal engines, note all other FWD cars (that i've seen) have the transmission on the driver's side. I removed mine by putting the car in 5th gear and holding the brakes while having a friend stand on a ratchet with a long bar for leverage and it came right off.
There have been soo many threads created on this subject that mods should start deducting points every time a new crank pulley removal thread is created.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMOrangeFever »</TD></TR><TR><TD CLASS="quote">If you have to do it ghetto.. i just have someone hold a screwdriver to the flywheel and use a breaker bar and loosen the nut.</TD></TR></TABLE>
yeah thats how i did it. my impact gun wasnt doing **** and it was an ingersol-rand 1/2 too
i work at a honda delership and the way we do it is you heat the **** out of it to get the flat washer behind it hot and take an impact gun with a short socket on it (has to be short for tourqe) and it will come right off.. and yes its righty tighty lefty loosy
Yea, I know I screwed up the crank pulley, someone say it again, "Hey man you screwed up your crank pulley!" It's okay, I wish I could say I didn't know better, but I did know better. I thought what the hell, maybe it will break loose without separating from the rubber. Really it didn't matter whether I was torqueing the hell out of the small pulley or the large, the thing was going to separate cuz' all I have for an air compressor is a 35 gallon CH with about 7.5 SCFM at 40PSI and about 5.4 at 90psi.
My biggest fear is breaking that bolt off in the crank.....I think I'm done----I'll just call somebody with the tools and pay them to put the new stuff in. By the way my manual says that thing is torqued to 130 ftlb. ,on this 97 HX.
Anyway thanks for the suggestions and help. I buttoned her all up and drove it to work all this week, no problems, but I am sure when they pull the pulley off it will separate and the guy will call me at my home and say "Hey man you screwed up your crank pulley, you need another one man I can install it for about $150 big green smackers, dude----no good without it man. And I'm gonna say, damn well worth it , dude! I just turned 289, 500 miles on this thing and all I have ever done is basic maintenance. I knew it would cost me some day.
I just had to do this to mine but I had the tranny pulled when I did it because I just replaced the rod and main bearings. I put a screw driver through one of the bolt holes in the flywheel that the clutch attaches to and turned the motor to where the screwdriver held it still. Then I took a breaker bar and broke it loose. I had to use my foot to do it... good luck those things are b!tch *** tight. Honda tightens those to 200ft lbs from what Ive heard.
when i did and it probably took about less than 5 minutes to do ..
1) take the boot off of the not all the way just to see the hole slave cylinder goes in(one on transmission)
2) stick a flat head screw driver through the hole
3)try and find the holes in the fly wheel and stick the screw driver in there
4) get someone to hold the screw driver for about 3 mins
5) brake the crank pulley bolt
6) your home free
6) your home free
i was just lookin out for the post creator.
