O2 sensor CEL
Old Jun 16, 2005 | 03:54 PM
Pariah's Avatar
Default O2 sensor CEL
My car is OBDII, so I have two o2 sensors. One before the cat and one after.
I started getting a CEL when I put on my header. It was made for the D16Z6 and I have a D16Y8. My factory o2 sensor is at the top of the exhaust manifold, but the header has it at the end of the header. I had to lengthen the wires quite a bit, and since then, the CEL goes on. I pulled the code at an automotive place and it says Slow Response From O2 Sensor. Once reseted, the CEL would come on about once every two weeks.
Now I put on a high flow cat. The problem was the O2 sensor bungs were in front of the cat, so my first and second O2 sensor are right next to each other. I did some research and found that the first O2 sensor is responsible for making sure of the 14.7:1 air-fuel mixture is correct and makes adjustments based on it's reading and the second O2 sensor makes a comparison to see what the cat burns off.
What should I do? I believe the engine just goes with a generic air-fuel mixture when it can't get a reading from the O2 sensor. And VTEC still kicks in, so the CEL isn't affecting that fortunately. Everything runs fine. But now I have a constant CEL on from the O2 sensors. Is there a way to bypass this at all?
Old Jun 17, 2005 | 04:46 AM
dwnthehatch's Avatar
Default Re: O2 sensor CEL (Senses Fail y0!)
You have 2 options.
1. Get an o2 simulator.
2. Get a bung welded after the cat and plug the old bung.
Old Jun 17, 2005 | 05:25 AM
Ricey McRicerton's Avatar
Default Re: O2 sensor CEL (dwnthehatch)
How do the 02 simulators deal with the heater? Do you have to splice into your primary 02 harness for the heater signal?
Old Jun 17, 2005 | 10:24 AM
Pariah's Avatar
O2 simulator?
I'm thinking I'll just go with an OBD1 conversion and run a chipped P28 ecu to get rid of the O2 sensor reading
bgoetz
Jun 8, 2005 07:50 AM
wootcivic
Nov 29, 2004 10:01 AM
gsrvtechatch93
Mar 29, 2004 08:48 PM
Etylorcen
May 6, 2002 04:28 PM
degradated
Nov 5, 2001 02:57 AM
