good lsd for s2k?
my buddy has an 00 s2k and he messed up his lsd
. whats a good one that isn't too pricey? how long do they usually last on an s2k? If you can add some positives and negatives on any of the lsd, please do. Any help will be greatful. thanks
to change the whole diff? if its the full assembly, shouldn't be too much. a couple hundred i would guess. if you need to put in gears and such, expect to pay more
currently i running the spoon 1.5 way lsd...but for labor costs i not sure how much would it be just for lsd cuz i did the clutch, fly and lsd at same time...labor was like 450 cdn around...and i would recommend if u don't track or race your car on circuit don;t even bother..oem lsd is enuf...diu to the annoying clunking sounds u get from aftermarket lsds...it really depends which brand u go for..some will make it super loud some won;t...basically sounds like broken cv joints when your driving
what does lsd stand for??
by the way nishant, i was looking for personal input on the differences between 00-03 vs 04-05's, and found mostly technical differences (differences which i knew) but no luck finding personal input, and how what they liked, didn't like of the changes/modifications
so now i'm taking you up on your offer, could you please forward me a thread, or post with the mentioned above differences?
many thanks
Alex
many thanks
Alex
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kungura »</TD></TR><TR><TD CLASS="quote">what does lsd stand for??
many thanks
Alex</TD></TR></TABLE>
lsd stands for limited slip differential...and hope u find the answers on differences between ap1's and ap2's...sorry can't really help u on that one
many thanks
differences between 00-03 and 04+:
2.2L motor, 8k redline, different 1st-4th gear ratios, 17s, bigger brakes (0.2"), different front brake pads, door panels, 1 more cupholder, steering wheel, driveshaft, rear subframe, rear toe angle curve, stiffer front springs and sway bars/softer rears, wider different tires, LED taillights, different headlights, new F/R bumpers, new exhaust tips (the rest look the same
Most important of all: 9 LBS OF TORQUE~!!!
) Most important of all: 9 LBS OF TORQUE~!!!
i think he was asking for your opinion about the changes. i could be wrong? instead of the technical aspects of the new s2k's, post what you think about the changes they made.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ScreaminTeg »</TD></TR><TR><TD CLASS="quote">Let me add a question to this thread....
anyone here running a full 2-way LSD on the street? is it comfortable on the street?</TD></TR></TABLE>
I have a few friends that run 2-ways (not in s2000's but 240SX's)... you have to get used to how it reacts basically, and it kind of chirps the tires at parking lot speeds from locking.
Also makes a funny assed *thunk* noise in parking lots (normal).
If you drive normally/safely in the rain, you should be fine, but don't expect yourself to be able to drive any way you want in the rain.
other than that, they have no problems.
