Honda S2000 Honda S2000
Does the s2k have lsd
Old Jan 9, 2006 | 12:44 PM
Chesus-s2k's Avatar
Default Does the s2k have lsd
Does the s2k have lsd if not can u put lsd into it I don't know all the specs to the car yet so any info i can get is helpful thanx
Old Jan 9, 2006 | 01:19 PM
Mr. Projekt's Avatar
* B A N N E D *
Default Re: Does the s2k have lsd (Chesus-s2k)
It has a Mazda Torsen mechanical LSD stock. Replacements are available from Cusco, OS Giken, KAAZ, J's, Spoon, Mugen... you name it.
Old Jan 9, 2006 | 01:37 PM
Chesus-s2k's Avatar
how come it has a mazda lsd
Old Jan 9, 2006 | 01:44 PM
Chesus-s2k's Avatar
I was just doing some reserch on lsd for the s2k and i seen some 1, 1.5, and 2 way lsd what is the driffrence between them
* B A N N E D *
Default Re: (Chesus-s2k)
Because outsourcing a proven part is cheaper than researching and developing a completely new unit.
If you don't understand the need for a 1.5 or a 2 way LSD, you shouldn't upgrade to it. It all depends on the purpose of the car, and the drivers style.
Old Jan 9, 2006 | 04:57 PM
Will_ChinLee's Avatar
in short the difference between a 1, 1.5 and 2 way is when the LSD will engage durring Acc. and Decel. on a 2 way, it is both, however on a 1 way it is only Acc.
Old Jan 10, 2006 | 05:02 AM
Francesco's Avatar
Default Re: (Will_ChinLee)
im pretty sure they used a mazda lsd because most of the aftermarket gears for the s2000 are actually re labeled mazda gears also...
Old Jan 10, 2006 | 05:08 AM
papa5murf's Avatar
Default Re: (Francesco)
just leave your LSD stock.... it's gets complicating after a while.... it's one of those things that if you don't know what it does. leave it alone...
Old Jan 10, 2006 | 05:25 AM
Francesco's Avatar
Default Re: (papa5murf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by papa5murf &raquo;</TD></TR><TR><TD CLASS="quote">just leave your LSD stock.... it's gets complicating after a while.... it's one of those things that if you don't know what it does. leave it alone...</TD></TR></TABLE>
yeah i agree...theirs a few variations out there
Old Jan 10, 2006 | 08:49 AM
-NA-aLL-thE-wAy-'s Avatar
EFSS153
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">
yeah i agree...theirs a few variations out there </TD></TR></TABLE>
Me third.
Old Jan 10, 2006 | 08:57 AM
WowOzYouRock's Avatar
Default Re: (NAallTheWAY)
if you compete for drifting then its A MUST
Old Jan 10, 2006 | 08:59 AM
* B A N N E D *
Default Re: (Y2K_S2K)
In drifting, most will go with the 2 way, and some, like myself, are using the 1.5.
Old Jan 10, 2006 | 09:17 AM
ITRbroham's Avatar
shit post warrior
Default Re: Does the s2k have lsd (Slideways2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slideways2000 &raquo;</TD></TR><TR><TD CLASS="quote">It has a Mazda Torsen mechanical LSD stock. Replacements are available from Cusco, OS Giken, KAAZ, J's, Spoon, Mugen... you name it.</TD></TR></TABLE>
Remember, those aftermarket LSDs named above are the clutch type which differs from the Torsen or helical type that comes standard in the S2K. IIRC, it is only 1 way.
Old Jan 10, 2006 | 09:54 AM
Default Re: Does the s2k have lsd (ITRbroham)
remember :
clutch type are most use for drift cars
torsen (from the word torque sensing) are most use for off road
Old Jan 10, 2006 | 10:48 AM
Francesco's Avatar
Default Re: Does the s2k have lsd (Y2K_S2K)
a 1.5 way lsd fully works one wheel and partially the other, right? 2 way is both wheels?
Old Jan 10, 2006 | 10:59 AM
* B A N N E D *
Default Re: Does the s2k have lsd (Francesco)
1.5 works partially on deceleration, and fully on acceleration. 2 ways gives full limited-slip effect on both accel and decel. I use a lot of engine braking, and end up locking the wheels unnecesarily on a 2-way (I've tried ). 1.5 gives me the balance that fits my style, and the control that I need.
Old Jan 10, 2006 | 11:03 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">a 1.5 way lsd fully works one wheel and partially the other, right? 2 way is both wheels?</TD></TR></TABLE>
no...
1 way locks only when accelerating ...
1.5 way is almost like 2 way .. less lock when decelerating ...
2 way lock in both acceleration and deceleration ...
Old Jan 10, 2006 | 11:29 AM
Francesco's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Y2K_S2K &raquo;</TD></TR><TR><TD CLASS="quote">
no...
2 way lock in both acceleration and deceleration ...</TD></TR></TABLE>
good info i remember reading about lsd's before, just never looked into more information beccause i knew it was something i would have the need to upgrade in the s2000
Old Jan 10, 2006 | 01:08 PM
Chesus-s2k's Avatar
i want to start drifting with my s2k in the spring so would it be best to get a new performance lsd or stock
Old Jan 10, 2006 | 01:18 PM
Chesus-s2k's Avatar
and how can you macth the clucth with the lsd
Old Jan 10, 2006 | 07:48 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chesus-s2k &raquo;</TD></TR><TR><TD CLASS="quote">i want to start drifting with my s2k in the spring so would it be best to get a new performance lsd or stock</TD></TR></TABLE>
I can drift the stock S2k just fine. Don't upgrade if you can't grasp the starting point.
Old Jan 10, 2006 | 08:12 PM
Francesco's Avatar
you know the s2k isnt the ideal drift car right?
Old Jan 11, 2006 | 04:57 AM
papa5murf's Avatar
you know the s2k isnt the ideal drift car right?</TD></TR></TABLE>
sure it can..... with our "snap" oversteer... it's actually quite logical... get into an oversteer and then slightly correct and you're in a drift...
on top of that it's easy to toss the rear end out on the S.....
Old Jan 11, 2006 | 05:05 AM
Francesco's Avatar
on top of that it's easy to toss the rear end out on the S.....</TD></TR></TABLE>
i know where your going with this, but this is all upon the driver. sometimes the s2000 goes where it wants to go in an fish tail.
Old Jan 11, 2006 | 09:29 AM
* B A N N E D *
Hey Frank, take your car on the downhill. You'd be surprised how easy it is to throw it into a FOUR WHEEL DRIFT. I'm not joking. It doesn't snap if you ease it in. The AP1 is a bit too snappy to do it, but the revised suspension tuning on the AP2 takes it just fine.
