my car revs up and down even if my gas peddle is pressed steadily?????
Old Jun 16, 2005 | 02:27 PM
EKB18BPR3's Avatar
Default my car revs up and down even if my gas peddle is pressed steadily?????
my POS car (see sig) revs up and down when my gas peddle is held steadily. what would cause my car to do that? sensors? i replaced ecu with known-good one but did the same. im a nissan mechanic and my obd reader doesnt read honda codes. please help me out. ive unplugged each sensor and drove it one at a time but kept doing it every time. im about to blow it up.
Old Jun 16, 2005 | 02:50 PM
thaiphob's Avatar
Nikon!!!
Default Re: my car revs up and down even if my gas peddle is pressed steadily????? (98B00STED)
vaccum leak.
Old Jun 16, 2005 | 03:00 PM
EKB18BPR3's Avatar
Default Re: my car revs up and down even if my gas peddle is pressed steadily????? (thaiphob)
vacuum leak? ive checked that but ill check again. anybody else?
Old Jun 16, 2005 | 03:04 PM
shermanyang's Avatar
is the check engine light (CEL) on? if it is it's VERY EASY to check the codes. if there aren't any codes, it might possibly be a vacuum leak.
Old Jun 16, 2005 | 03:16 PM
Ricky Rojales's Avatar
I'd call an exorcist.
Old Jun 16, 2005 | 05:13 PM
EKB18BPR3's Avatar
Default Re: my car revs up and down even if my gas peddle is pressed steadily????? (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">is the check engine light (CEL) on? if it is it's VERY EASY to check the codes. if there aren't any codes, it might possibly be a vacuum leak.</TD></TR></TABLE>
i got check engine light and im sure if i find out what it is, i can fix it but like i said the only obd reader im accessible to is for a nissan one. i tried jumping the two-wire connector but the light didint flash.
Old Jun 17, 2005 | 11:32 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98B00STED &raquo;</TD></TR><TR><TD CLASS="quote">
i got check engine light and im sure if i find out what it is, i can fix it but like i said the only obd reader im accessible to is for a nissan one. i tried jumping the two-wire connector but the light didint flash.</TD></TR></TABLE>
maybe you jumped the wrong plug? or maybe the wire you used didn't make a solid connection?
Old Jun 17, 2005 | 11:38 AM
neo1z's Avatar
Search for pictures of the plug, and how to do it. There are pictorials on here - it will work if done correctly. Sounds like a vacuum leak for sure. Any recent intake manifold, intake, or throttle body changes?
Old Jun 17, 2005 | 07:59 PM
cleantegra's Avatar
vacuum leak was my 1st guess. your TPS might be jacked, have that checked out.
search "idle surge"
Old Jun 17, 2005 | 08:25 PM
honda011's Avatar
Default Re: my car revs up and down even if my gas peddle is pressed steadily????? (honda011)
my fault u already did it i dind't read the hwole post and are u sure the paper clips are in correctly and u did it to the brown n black plug?
Old Jun 17, 2005 | 08:48 PM
sapo's Avatar
tow it to Tanner honda dealer in Brainerd and have them run a check for codes.
Old Jun 18, 2005 | 10:32 AM
EKB18BPR3's Avatar
Default Re: (sapo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sapo &raquo;</TD></TR><TR><TD CLASS="quote">tow it to Tanner honda dealer in Brainerd and have them run a check for codes.</TD></TR></TABLE>
yea i work for tanner nissan so they will hook me up but that thing is i gotta get it towed over there...$100 from staples, mn.
i got codes 41, 3, 10. can someone help me out with these?
honda11111
Mar 29, 2007 03:51 PM
egturbolsvtec
Mar 15, 2006 03:20 PM
LAKER HATER
Feb 6, 2005 08:55 PM
mikester_91
Jan 11, 2005 05:20 AM
