axles not alined properly...motor hitting hood under torque
I have a 92 civic with b16a(jdm). Heres my problems i recently re-did my axles and the shop (my brother) said the axles arent lined up properly. He says the motor is sitting too far foward and a little bit up(causing me to go through axles). I thought getting aftermarket mounts would help but hasport said there mounts are the same as stock just stronger. I took my car to the people who did they swap, and they say i need a new rear engine mount. i agree with them the mount is bad cause under torque the engine will ding the hood.....but will a new rear mount fix my axles alignment problem. Any one have this problem or know whats wrong? All suggestions and commets welcome!!!!!!!!
THANXXXXXXX
THANXXXXXXX
i thought HAsport mounts positioned the motor diffrently too but wen i called Hasport a guy told me they were the same as stock mounts just stronger(he coulda just been talkin outa his ***)i would have no problem buying the mounts but i wanna make sure it will correct the problem before dropping 450!
thanx HAM.....any one have more info on this, will hasport mounts correct the problem?
what mounts did you use for the swap?... maybe you have the wrong mounts altogether which could cause your motor to sit funny and also prematurely wear them out
Im told i am using "stock" mounts. I am not sure weather they mean stock b16 or stock eg(im guessing eg) If i got hasport mounts would my motor sit correctly or could there still be other things going on? The rear mount is defanitly shot but i was told the front 2 are good. ANY IDEAS?.....
if your mounts are shot the torque of the motor is easily gonna move the motor ! jus get either new stock mounts or some aftermarket mounts ! should cure your problem
thanx.....the motor under torque hitting the hood is understandable but should the motor sit out of place with a shot mount while not started? does Hasport make a kit for b series cable trans(mines converted to hydro doesnt manner right?) into an eg ? thanx for all the help u guys are awesome
OEM B16A and D16 mounts are the same, the brackets are different, but they have the same placement. You mounts are problably shot to hell, either get some instert like Energys, or thebuy all new OEM, or HAsports if you want.
I had the same problem. Its hitting on the left side, right over your valve covers ends right?????
Mine was so bad that when I put the turbo on, the wastegate punched a hole through my hood. I posted about this about a week ago.
All I did was replace the mounts that were bad and put some energy motor mount inserts in. Problem solved.
I am also gonna give you some advice. If it hasnt already happened yet, it will,...... SEARCH SEARCH SEARCH SEARCH be4 you post. These guys are ruthless about flaming you.
Hope my opinion is helpfull. Oh yeah, You really should try AND FIND OUT WHICH MOUNTS YOU ARE USING,...THAT WILL HELP DIAGNOSE URE PROBLEM BETTER
alright thanx guys....im gonna get the hasport mounts(or OEM) and tell u if it solves my problem. Im almost positive the car was never in an accident but ill def look into that!!! I like the stock mount feeling....which mounts would you guys get and why? Prices on OEM?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj »</TD></TR><TR><TD CLASS="quote">I see some HEAVY DUTY FLAMING coming to you
Quit wasting posts with useless response like this. Plain and simple, once is enough, twice gets gay.
Replace the broken mount, see what it does for your problem. Personally, I wouldn't use any aftermarket mount kit for an EG... Use the 94+ Integra mounts and then you KNOW its going to sit in the correct spot. I will however say I have used the Hasport mount kit for an EG coupe with a B16 swap and it worked out perfectly.
</TD></TR></TABLE>Quit wasting posts with useless response like this. Plain and simple, once is enough, twice gets gay.
THIS is how flame wars get started. I was just trying to save this guy some grief. I warned him once about searching and then he asked an equally rhetorical question. I wish someone had warned me like that.
i did searchs on the topic i put in things like axles not aligned and motor hitting hood and various forms of that but i didnt find answers to my questions....ill search harder before posting i was just trying to get the problem resolved
... as for the 94+ teg mounts i havent heard of that yet...but ill be doing a search soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj »</TD></TR><TR><TD CLASS="quote">THIS is how flame wars get started. I was just trying to save this guy some grief. I warned him once about searching and then he asked an equally rhetorical question. I wish someone had warned me like that.</TD></TR></TABLE>
Dude, just quit responding unless you have something to contribute to this, please!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Tec »</TD></TR><TR><TD CLASS="quote">i did searchs on the topic i put in things like axles not aligned and motor hitting hood and various forms of that but i didnt find answers to my questions....ill search harder before posting i was just trying to get the problem resolved
... as for the 94+ teg mounts i havent heard of that yet...but ill be doing a search soon. </TD></TR></TABLE>
What do you mean you haven't heard of it? I have done several swaps using stock 94+ Teg mounts for B series into EG's.. Its fits like stock because they are stock mounts. No allignment issues, etc to deal with. But like I said, the one time I did use Hasport mounts, I had no issues either. I would chaulk it up to your one broken torque mount.
... as for the 94+ teg mounts i havent heard of that yet...but ill be doing a search soon. </TD></TR></TABLE>What do you mean you haven't heard of it? I have done several swaps using stock 94+ Teg mounts for B series into EG's.. Its fits like stock because they are stock mounts. No allignment issues, etc to deal with. But like I said, the one time I did use Hasport mounts, I had no issues either. I would chaulk it up to your one broken torque mount.
Hybrid93Eg Thanx bro uve been a lot of help. Now i just gotta decide if i want to use stock or aftermarket mounts...Ill tell u how it goes when im done. Thanx for giving the imput and not flamming like other people...not to mention any names tho!
kenttouchthis
Aug 24, 2008 04:09 PM
Charlie Moua
Apr 10, 2002 04:02 PM
