Symptoms of bent valves?
Old Jun 16, 2005 | 11:00 AM
Morning Call's Avatar
Default Symptoms of bent valves?
what are the symptoms of bent valves..
do you hear them? or is it strictly in the performance of your engine.. i hear no clicking noises... my timing is as good as it ges.. (one tooth back i get clicking noises under a quick tap of the throttle, and same for one tooht forward)
Old Jun 16, 2005 | 11:18 AM
chirp3rd's Avatar
Default Re: Symptoms of bent valves? (Morning Call)
idle will be inconsistant and rpms would drop considerable with my few experiances the car would die at idle do a leak down test or while the car is on one by one pull your spark plug wires out 1 cylinder at a time idle should change when you pull one out if not somethings wrong.
Old Jun 16, 2005 | 12:23 PM
ok sounds good.. ive pulled the sparks before and the idle changes...
the reason im asking is cause i did the timing on my car a very very ghetto way.. (didnt do TDC for the crank... ).. so id change the cam timing a tooth at a time until it was correct...
but in doing that, i had the cam slip on me a time or two and lost where i was at.. so id set the belt on, try to start it and bam.. engine locked up... pretty much rocked my whole car.. that happened twice.. but i have the engine timed fine, and it runs fine.... it just seems like my gas mileage isnt as good as it should be...
and yes i know the wya i timed my car is not good
jonnyshatter
Dec 27, 2013 02:37 PM
StevenGunn
Nov 21, 2010 03:23 PM
b16a4
Sep 12, 2007 06:02 PM
3rdGteg
Nov 1, 2002 09:31 PM
cbmlsvteg
May 24, 2002 02:18 PM
