injector choice to go with?
which injector to go with and what size? peak hold or saturated, 270cc or 310cc would i need some type of management?
setup:
98 GSR head
port & polish, 3 angle valve job
ITR valve springs
ITR valves
ITR cams
98 GSR block
81.25 JDM ITR piston
ITR ecu
i think this setup would be about 11:5:1 comp.
Modified by luckypon7 at 11:01 AM 6/16/2005
setup:
98 GSR head
ITR valve springs
ITR valves
ITR cams
98 GSR block
ITR ecu
270 would be good for that setup. but if your going run hondata or something to that nature going bigger wont hurt. you can always detune the fuel delivery. plus itll give you room to upgrade your internals or bolt ons later on. and i believe saturated is what you want. someone correct me if im wrong.
so 270cc would be enough for this setup and the ITR ecu would be able to controll it with out any engine management help? it won't run lean with that compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked »</TD></TR><TR><TD CLASS="quote">310 saturated. 270's may not do the job if you run big cams.</TD></TR></TABLE>true. thats why i say run larger injectors. and tune the fuel delivery. but 270s would be good for this specific application.
no big cams just the ITR cams
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luckypon7 »</TD></TR><TR><TD CLASS="quote">
no big cams just the ITR cams</TD></TR></TABLE>
270's will work fine then.
92integraVTECgsr
11
May 29, 2008 04:28 AM
