is my car overheating
hey wasup people i have a b16a crx and it just started overheating a bit like about 3/4, after i drive it for 10min the needle starts goin up slowly should i get the thermostat replaced or should i look for other problems? pls help its my only ride and never had this problem before. oh and by the way does anyone know of any shops that could help me out around san berdo area? and if theres anyone around that can help me out wit that ill pay you a couple bucks.
hot or cool spots on the radiator? This could be clogged radiator. Is the lower rad hose hot when engine is warmed up? If it is cool it could be your thermostat. A simple one, have you checked your coolant level? What ratio of coolant to water are you running? Just a few things to try.
Hope it helps, let us know what you find.
no spots on the radiator, the bottom radiator hose seems warm i guess normal for bein under the hood but not to hot , and im using the 50/50 coolant, damn to bad i suck at mechanics or id take out the thermostat myself
EGcivic_95
31
Jan 29, 2011 06:09 PM
turbotime
Oct 11, 2005 10:08 PM
