Car doesn't go past 5 grand.
Old Jun 15, 2005 | 01:22 PM
ocdcivic's Avatar
Default Car doesn't go past 5 grand.
So like the title says.....
I have a 99 b18 type r JDM motor and tranny in my 99 ls. I just put a USDM P72 ECU in it (GSR I Believe) and I can't get the motor to rev past 5 grand. I am also noticing a check engine light for a crank shaft fluctuation sensor. Could not having that sensor cause my problem? Or do I need a different ECU? Any help would be great.
Old Jun 15, 2005 | 01:33 PM
IHateJDM's Avatar
Default Re: Car doesn't go past 5 grand. (ocdcivic)
That sounds like the real 'limp mode'. Fix the cel and you should be fine. You can either add the sensor, or get a chipped p28.
Old Jun 15, 2005 | 02:29 PM
ocdcivic's Avatar
Default Re: Car doesn't go past 5 grand. (IHateJDM)
Do you know if a chipped P28 would be compatible with the NYS inspection system. That is the problem I am ruinning into getting the car to pass inspection.
Old Jun 15, 2005 | 03:16 PM
unknown0001's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ocdcivic &raquo;</TD></TR><TR><TD CLASS="quote">Do you know if a chipped P28 would be compatible with the NYS inspection system. That is the problem I am ruinning into getting the car to pass inspection.</TD></TR></TABLE>
If it's chipped it should work good and pass also
Old Jun 15, 2005 | 03:28 PM
-97accord-'s Avatar
Default Re: Car doesn't go past 5 grand. (Mr.RHTuner)
most likely the ECU. it hapend on my swap, the car starts to lag around 4500 rpm then at 5000 the rpm stick just stops.
Old Jun 15, 2005 | 04:15 PM
ocdcivic's Avatar
Default Re: Car doesn't go past 5 grand. (-97accord-)
Yeah it literally just stops but I got a hold of a P73 so i am gonna try that out tommorow. Thanks for all of the help and I will let you guys know what turns out.
Old Jun 16, 2005 | 11:25 AM
ocdcivic's Avatar
Ok so I tried a USDM p73 and it now stops at 6 grand. It is throwing the code 54 (flux sensor). Now when I had the JDM ECU in it wasn't looking for that sensor nor was it throwing that code. I went to install a new sensor but the USDM one doesn't seem to match up to the block. I don't know if it's because it's a JDM motor and the USDM doesn't fit or what. Any other suggestions???
Sycokid666
Feb 14, 2017 05:10 PM
elmejor
Jul 5, 2008 10:40 PM
`chrisb
10
Jan 21, 2008 05:07 PM
ED6JDM
Nov 16, 2006 06:53 PM
streetracerof06
10
Dec 29, 2005 06:14 PM
