6.5" speakers fit in EG hatch and rear?
Old Jun 15, 2005 | 10:22 AM
b18c4door's Avatar
Default 6.5" speakers fit in EG hatch and rear?
Ok, crutchfield claims only 5.25" will work in my 95 SI hatchback. I was wondering if I could pull of 6.5" speakers? Anyone done this? If so, what brand did you use? Depth is probably a concern !?! Thanks!
Also, I was considering a 5.25" midbass in the rear, will that work or again will depth be the issue?
Thanks!
Old Jun 15, 2005 | 10:55 AM
fcm's Avatar
fcm
Old Fart
Default Re: 6.5" speakers fit in EG hatch and rear? (b18c4door)
I have never seen a 5.25" speaker in any Honda/Acura 4" in some of the older ones 6x9" in some newer ones the rest have all been a "standard" 6.5", not the new "over sized" 6.5" on most pre 96 Honda/Acuras the oem speaker mount, [front] have a screw hole pattern, [4 screws] for 5.25" speakers although they come with 6.5" speakers, in Canada anyway, the mounts also have the 3 screw hole pattern for the 6.5" speakers, and yes depth is an issue, you can gain up to 3/4" if you cut out the back of the speaker mount, and depending on the speaker, up to 3/4" if you add a spacer ring. For best sound replace the oem plastic mounts with custom MDF ones. 94
Old Jun 15, 2005 | 02:40 PM
b18c4door's Avatar
Default Re: 6.5" speakers fit in EG hatch and rear? (fcm)
thanks, but believe me - check crutchfield.com and choose 95 Honda Civic SI and you will see what I mean. I will replace the rings as well with MDF ones. Thanks!
Old Jun 16, 2005 | 02:27 PM
allanonjj's Avatar
That is NOT TRUE AT ALL!!! Ive owned 4 92-95 civics and all 4 of them use 5 1/4 " speakers in the doors. I think my 94 4dr had 6 1/2's in the rear decklid. I can promise you that this info is true. I fiberglassed some enclosures for my front door panels so that I could put 6 1/2's in the doors. It is REALLY easy to do and I will try to post some pics when I get my car back (getting painted, will have it back monday). It'll cost you about 50 or 60 bucks to do and it will take about 2 hrs (other than the time it takes tyhe glass to dry) to do.
Old Jun 16, 2005 | 06:58 PM
b18c4door's Avatar
Default Re: 6.5" speakers fit in EG hatch and rear? (allanonjj)
Yep, I agree. To double-check - I popped off the side panel speaker cover/grill and pulled out the rear speaker - guess what - its a 5.25"...I measured it.
I am going to check the doors as well next.
Anyone know where I can get a 5 1/4" spacer ring? That would help my install
Old Jun 17, 2005 | 07:11 AM
DougNuts's Avatar
You can get these adaptors to fit 6.5s evidently.
http://www.crutchfield.com/S-5...27802
I wish I knew what mounting depth I could fit in the doors. I want to put a 6.5" component set in the doors and move the 5.25" speakers to the back.
Old Jun 17, 2005 | 08:25 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj &raquo;</TD></TR><TR><TD CLASS="quote">That is NOT TRUE AT ALL!!! Ive owned 4 92-95 civics and all 4 of them use 5 1/4 " speakers in the doors. I think my 94 4dr had 6 1/2's in the rear decklid. I can promise you that this info is true. I fiberglassed some enclosures for my front door panels so that I could put 6 1/2's in the doors. It is REALLY easy to do and I will try to post some pics when I get my car back (getting painted, will have it back monday). It'll cost you about 50 or 60 bucks to do and it will take about 2 hrs (other than the time it takes tyhe glass to dry) to do.</TD></TR></TABLE>Don't tell me that it's not true at all, I have been an installer for over 30 years, and have yet to see a 5.25" speaker in a Honda/Acura, I said that the speaker mounts had the screw holes for a 5.25" speaker, but that they all came with a STANDARD 6.5" speaker, in CANADA anyway, read the post, BTW how many screws where used to mount the 5.25" speakers in your cars?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">Yep, I agree. To double-check - I popped off the side panel speaker cover/grill and pulled out the rear speaker - guess what - its a 5.25"...I measured it.
Anyone know where I can get a 5 1/4" spacer ring? That would help my install</TD></TR></TABLE> How did you measure it, from where to where, and same question to you, how many screws are used to mount your 5.25" speakers?
Don't forget what speaker manufactures are calling 6.5" speakers now a days is an OVER SIZED 6.5" they are not STANDARD 6.5" speakers.
Again I am not saying that no Honda/Acura ever came with 5.25" speakers but in 30 years of installing I have not seen one, in Canada anyway, also if you measure the cone on a STANDARD 6.5" speaker, it's about 5.25", the biggest diff., [other then size]between a 5.25" and the 6.5" is the way they mount the 5.25" speaker basket is almost square and has mounting holes in the 4 corners of the basket for mounting the speaker, the STANDARD 6.5" speaker basket is round and uses 3 screws to mount, most aftermarket STANDARD 6.5" speakers will have a number of holes/slots, for diff. mounting patterns, [Ford offset 4 screw mount]94
Old Jun 17, 2005 | 10:32 AM
b18c4door's Avatar
OK, here are pics of me removing and measuring. Hope this helps!
Old Jun 17, 2005 | 10:36 AM
DougNuts's Avatar
My '93 Civic has 5.25" speakers in the front.
I haven't been a professional installer for 30 years, nor do I live in Canada.....But I did stay at a Holiday Inn Express last night.
Old Jun 17, 2005 | 01:29 PM
allanonjj's Avatar
Dude, dont get so offensive. It really doesnt matter how long youve been installing, (Ive been doin it for about 10 yrs though, he he,.... couldnt help it). I know what I know and in this case,......I KNOW WHAT SIZE SPKRS GO IN A 92-95 CIVIC.
Old Jun 17, 2005 | 01:33 PM
allanonjj's Avatar
On the ring spacer, I would wait if I were you. My car is getting painted right now but as soon as I get it back (prob mon or tues) I will post pics of the door enclosures I made for my 6 1/2's. They take the place of your stock speaker grills and they are easy to make. I will give you detailed instructions on how to do it or I will just sell you mine and make some more. With this enclosure, you get a much tighter sound and like I said, It is easy. 1 1/2 hrs max!!!
Just remind me(ADD lika a ****,..I WILL forget)
Old Jun 17, 2005 | 02:26 PM
b18c4door's Avatar
I am waiting. I would love to see pics! Thanks!
Old Jun 18, 2005 | 08:03 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c4door &raquo;</TD></TR><TR><TD CLASS="quote">OK, here are pics of me removing and measuring. Hope this helps!
</TD></TR></TABLE>That is a 5.25"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj &raquo;</TD></TR><TR><TD CLASS="quote">Dude, dont get so offensive. It really doesnt matter how long youve been installing, (Ive been doin it for about 10 yrs though, he he,.... couldnt help it). I know what I know and in this case,......I KNOW WHAT SIZE SPKRS GO IN A 92-95 CIVIC. </TD></TR></TABLE> Not in Canadian 92/95 Civics , offensive, whats that mean? You said "That is NOT TRUE AT ALL" I said, don't tell me that, I have yet to see a 5.25" speaker in a Honda/Acura in over 30 years of installing, and I qualified it by saying "in Canada anyway" How is that "offensive"?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DougNuts &raquo;</TD></TR><TR><TD CLASS="quote">My '93 Civic has 5.25" speakers in the front.
I haven't been a professional installer for 30 years, nor do I live in Canada.....But I did stay at a Holiday Inn Express last night.</TD></TR></TABLE> LMAO now that cracks me up. I always wondered why the screw mounts for a 5.25" speaker where in the speaker mounting basket of Honda/Acura when every one I have seen comes with a 6.5", I have even installed more then a few 5.25" speakers in them, [most leave a small gap around the edge, so the speaker is not sealed] even checked with my local Honda dealer, they only have a p/n for a 6.5", [for front doors] Also checked at Acura, same thing, Both Honda and Acura parts Dept. could not tell me what the extra holes where for, other then to say, maybe other countries use smaller speakers, well daaaa. 94
Old Jun 20, 2005 | 09:17 AM
allanonjj's Avatar
Now see, that makes sense. Although I dont really understand why there would be different sizes for different countries. Must be that Canadians like to rock out!!!
Old Jun 20, 2005 | 10:21 AM
b18c4door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allanonjj &raquo;</TD></TR><TR><TD CLASS="quote">Now see, that makes sense. Although I dont really understand why there would be different sizes for different countries. Must be that Canadians like to rock out!!! </TD></TR></TABLE>
Else, they are just deaf!
Old Jun 20, 2005 | 09:30 PM
DISROK1's Avatar
i have 5 1/4 comp's in the rear and 6 1/2 comp's in front for my 94 cx hatch.
2 lazy 2 glass new mounts 4 6 1/2 in the rear!!!!
installing **** in other people's rides all day then having 2 do your own car suck's!!!!!!
Old Jun 21, 2005 | 05:45 AM
allanonjj's Avatar
Default Re: 6.5" speakers fit in EG hatch and rear? (DISROK1)
"installing **** in other people's rides all day then having 2 do your own car suck's!!!!!!"
AMEN TO THAT. I USED TO HATE WORKING ON MY OWN STUFF. THATS PROBABLY THE REASON WHY I CHANGED PROFFESSIONS!!
Old Jun 24, 2005 | 07:20 AM
allanonjj's Avatar
heres some pics. It looks like the enclosure is actually part of the door.
Old Jun 24, 2005 | 07:22 AM
allanonjj's Avatar
Do you think I should offer these up for sale in the 92-95 forums???
Old Jun 25, 2005 | 05:12 AM
allanonjj's Avatar
bump
Old Jun 25, 2005 | 10:39 AM
allanonjj's Avatar
B U M P
Kannan08
30
Nov 14, 2011 11:53 PM
fireblaze2k1
Audio / Security / Video
10
Mar 5, 2009 04:41 PM
marc100
12
Apr 26, 2008 06:07 AM
mizzoEG
Aug 22, 2007 01:02 AM
turboeg831
Jan 8, 2007 12:52 AM
