New owner, strange problem
Old Jun 15, 2005 | 06:57 AM
AITR's Avatar
Default New owner, strange problem
Hey everyone,
Got a new type R about a 2 month ago. Great car! But some strange things started happening.
Last week, as I was coasting through a parking lot, car was slightly rolling in neutral, the rpm's dropped low and the car died??
Started right back up and no problems since.
However, this morning, when I started the car the rpm was fluctuating. It kicked up to about 1500 rpm then down to 500 rpm, almost felt like it was about to die. It did that for a couple of seconds before settling to it's regular idle.
It's 01, with an intake, header and test pipe, with about 45k miles. Hope it's not anything serious.
Any advice???
Old Jun 15, 2005 | 07:23 AM
slackeR1366's Avatar
Default Re: New owner, strange problem (AITR)
My idle was fluctuating like that due to a bad Intake Manifold gasket.
are you getting a CEL?
Old Jun 15, 2005 | 07:45 AM
AITR's Avatar
Default Re: New owner, strange problem (R1366)
CEL is on, but due to the test pipe. Would an intake manifold gasket suddenly go bad?
Old Jun 15, 2005 | 07:55 AM
Nishant's Avatar
have you gotten the cel code checked? it could be throwing more than just the test pipe
Old Jun 15, 2005 | 07:56 AM
Bbasso's Avatar
Pull the code from the CEL anyway... maybe it will tell you other then the testpipe.
Old Jun 15, 2005 | 08:06 AM
Mugen Mike's Avatar
Default Re: New owner, strange problem (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">have you gotten the cel code checked? it could be throwing more than just the test pipe</TD></TR></TABLE>
Old Jun 15, 2005 | 08:55 AM
itr1244's Avatar
Default Re: New owner, strange problem (Mugen Mike)
-try resetting the ecu
-try adjusting the idle screw
-disconnect PCV electric connection (OBD2 = CEL , OBD1= still ok?
try the first 2 ..
i dont think it's a serious problem good luck
Old Jun 15, 2005 | 09:59 AM
AITR's Avatar
Default Re: New owner, strange problem (itr1244)
Where/how do you adjust the idle screw?
I'm also going to get the CEL checked out.
Thanks.
Old Jun 15, 2005 | 10:04 AM
Dave_B's Avatar
AIC??? maybe since it happened in neutral.
Old Jun 15, 2005 | 10:50 AM
Splat's Avatar
Collector-o-Guns and Drinker
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AITR &raquo;</TD></TR><TR><TD CLASS="quote">Where/how do you adjust the idle screw?</TD></TR></TABLE>
Leave that alone until you get the CEL's pulled.
Old Jul 11, 2005 | 05:09 AM
AITR's Avatar
Default Re: New owner, strange problem (Splat)
Finally got the code pulled at autozone.
136 and 137. Low voltage secondary 02 sensor and something else related to secondary 02 sensor. But I know it's because of the test pipe.
Please help!
It's taking away my new car joy.
Old Jul 11, 2005 | 05:31 AM
Dr Pooface's Avatar
You can pull the codes yourself with a paperclip.
http://www.c-speedracing.com/faq/06.php
Old Jul 11, 2005 | 12:28 PM
AITR's Avatar
Default Re: New owner, strange problem (Dr Pooface)
It's already been read. Any help???
Old Jul 11, 2005 | 03:17 PM
Dr Pooface's Avatar
check/replace your sparkplugs.
Old Jul 11, 2005 | 05:27 PM
Reid's Avatar
Global Moderator
I'd change the fuel filter and spark plugs to start with, just as general maintenance.
Old Jul 11, 2005 | 05:39 PM
Trev-R's Avatar
I have the same problem, mine comes from a bent valve. Does your car make a slighty louder than normal tick at idle?
Old Jul 12, 2005 | 05:28 AM
AITR's Avatar
Default Re: New owner, strange problem (Reid)
I thought the spark plugs didn't need to be changed for like 100k miles?
How much and where's the best place to purchase the fuel filter and spark plugs?
I don't think it's louder. Not much louder than my friends GSR...
Old Jul 12, 2005 | 12:22 PM
Larkin W.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr Pooface &raquo;</TD></TR><TR><TD CLASS="quote">check/replace your sparkplugs.</TD></TR></TABLE>
Definitely...It could be something as simple as the original owner handwashed the engine bay before selling the car to you and too much moisture got near the sparkplugs. Ive seen this happen many times.
cjwang2
May 24, 2017 07:40 PM
aarontrini85
Sep 28, 2010 04:52 PM
gsr-2nr
Jan 2, 2008 08:31 PM
Civicr2gs5
Oct 13, 2006 08:17 AM
AP-Signworks1
Nov 24, 2003 06:51 PM
