accidently put 87 octane in my ls/turbo....
Old Jun 15, 2005 | 03:51 AM
playboyace35's Avatar
Default accidently put 87 octane in my ls/turbo....
i have half a tank of 87 oct. what should i do?? mix it up with 91 octane with some octane booster? or what?
Old Jun 15, 2005 | 04:16 AM
Adam.'s Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (playboyace35)
Drain that ****.
Old Jun 15, 2005 | 09:18 PM
TheLastSpartan's Avatar
How'd you do that???
Old Jun 16, 2005 | 03:03 AM
Default Re: accidently put 87 octane in my ls/turbo.... (DarkKnight1)
yeah, how do u drain it?
Old Jun 16, 2005 | 04:11 AM
sudds's Avatar
I hope you guys are joking.
Old Jun 16, 2005 | 07:18 AM
miller.91.HB's Avatar
We just drained my buddies car by pulling the return line off the fuel pressure regulator. Connected our own line that went to a gas can. Started the car and drained the tank that way. Worked really well.
There is a drain bolt on the bottom of the tank. But I've heard stories about it not sealing again after it's been removed. Or you could just syphon it.
Old Jun 16, 2005 | 08:56 AM
crxtreme89h's Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (miller.91.HB)
Ummmm...............don't worry about it. Now if you ran Diesel fuel in your car I would worry. 87 Octane will not harm your car. Maybe over a long period of time. Just maybe
Old Jun 16, 2005 | 06:47 PM
slammed00si's Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (crxtreme89h)
dont go into boost until you run out and fill up with the good stuff. pretty easy and no draining needed.
Old Jun 16, 2005 | 07:17 PM
hybridpatient95's Avatar
this guy shook lol
Old Jun 16, 2005 | 09:08 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: (frankenfiend 04)
Stock motor/compression? Just drive it and don't boost it until the gas runs out. Then fill it with higher octane.
Or just throw in some octane booster in there right now.
Old Jun 16, 2005 | 09:39 PM
Sohc Driver's Avatar
Default Re: (shamoo)
just don't boost..until you burn it all out..
Old Jun 16, 2005 | 09:40 PM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Or just throw in some octane booster in there right now.</TD></TR></TABLE>
Octane boost is a surprising poor way to increase the octane rating of gasoline. You would be lucky to raise the octane rating of the 87 octane gas by even two points. Furthermore, it may contain organometallic compounds such as MMT or Ferrocene. Both of these have a tendency to destroy oxygen sensors and catalytic converters. But you have a couple of other choices. First of all, if it is available anywhere relatively close to you, get a few gallons of 100 octane gasoline. If you mix half a tank of 87 octane with half a tank of 100 octane, you will end up with roughly 93 octane. I know that 100 octane is available in Sacramento and Stockton. But I don't know if or where it is available in the Bay Area. Another option would be to add toluene to your gas. One gallon of toluene would be enough to raise the octane level of five gallons of 87 octane gasoline to 92 octane. But if you do this, it would also be a good idea to top your tank off with 91 octane. Because if you just pour one gallon of toluene into half a tank of gas, it will not be well mixed. Toluene can be purchased at most hardware stores that sell paint.
Old Jun 17, 2005 | 02:44 AM
Default Re: (StorminMatt)
thx, i think i'll do this and dont boost lol so that way im being for sure safe
Old Jun 17, 2005 | 06:41 AM
B18aCRiX's Avatar
last year wen i had my ls turbo i ran 87 octane all the time and boosted all day... my engine never blew and it wasent even tuned... i was runnin off of a fmu... im pretty sure u will be good.. but to be safe dont boost till u fill it with higher octane
Old Jun 17, 2005 | 08:37 AM
full_race_eg6's Avatar
what is this catalitic converter you speak of where does it live dood, just dont go into boost youll be fine ive actually had to get low octane when im on trips and thats all the gas station is 87 youll be allright just run your tank out as empty as you can get a little 105 say a gallon mix it with your 92 and your good to go. thats what i did at least.
Old Jun 17, 2005 | 03:18 PM
EKB18BPR3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">
Octane boost is a surprising poor way to increase the octane rating of gasoline. You would be lucky to raise the octane rating of the 87 octane gas by even two points. Furthermore, it may contain organometallic compounds such as MMT or Ferrocene. Both of these have a tendency to destroy oxygen sensors and catalytic converters. But you have a couple of other choices. First of all, if it is available anywhere relatively close to you, get a few gallons of 100 octane gasoline. If you mix half a tank of 87 octane with half a tank of 100 octane, you will end up with roughly 93 octane. I know that 100 octane is available in Sacramento and Stockton. But I don't know if or where it is available in the Bay Area. Another option would be to add toluene to your gas. One gallon of toluene would be enough to raise the octane level of five gallons of 87 octane gasoline to 92 octane. But if you do this, it would also be a good idea to top your tank off with 91 octane. Because if you just pour one gallon of toluene into half a tank of gas, it will not be well mixed. Toluene can be purchased at most hardware stores that sell paint.</TD></TR></TABLE>
i knew this was gonna come up
Old Jun 17, 2005 | 08:32 PM
The_Head's Avatar
You could take out your wastegate spring so you don't go into boost...
Old Jun 19, 2005 | 08:49 AM
shamoo's Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">You could take out your wastegate spring so you don't go into boost...</TD></TR></TABLE>
That would be loud and annoying to have it always open. Would be kinda cool though.
Old Jun 20, 2005 | 10:10 AM
LSDC-4's Avatar
gas is to damn expensive, but its well worth it
Old Jun 20, 2005 | 12:03 PM
stingray16_98's Avatar
another way to fix the problem and save the fuel thats extremely expensive these days is to go to the store and buy a family size bottle of rubbing alcohol for like 3 dollars and put that into the tank if you didnt have over a half tank of low octane gas. if money isnt a problem then draining the fuel is the best way to deal with the problem. once or twice a year isnt going to hurt your car just be more careful next time.
Old Jun 23, 2005 | 05:17 AM
The_Head's Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (shamoo)
That would be loud and annoying to have it always open. Would be kinda cool though.</TD></TR></TABLE>
I did it once... most of the engine bay was black, and I melted my hood release cable, lol
Old Jun 23, 2005 | 07:41 AM
GetawayInMoscow's Avatar
Do you have any friends?
Siphon that **** out and give it to them for free. Then go fill up with 91,92,93 whatever your state has. Not that hard.
Old Jun 23, 2005 | 09:36 AM
nickzed20's Avatar
Default Re: accidently put 87 octane in my ls/turbo.... (GetawayInMoscow)
ocatne booster is useless, is your motor tuned?
if its fine tuned with a stand alone i would probably fill the rest up with the highest octane you can find, and then just baby the car until it runs out
if its not tuned then just baby the car until the half tanks is gone and then fill it up
Boofster
Jul 9, 2006 05:54 PM
92eg6lsvtec
Jul 18, 2005 10:37 AM
Used2beAb16
39
Apr 8, 2005 06:09 PM
H22A EG6
Nov 27, 2003 09:52 AM
CovertFI
Jul 13, 2002 07:59 PM
