oops! regular gas
Old Jul 9, 2006 | 03:01 PM
Boofster's Avatar
Default oops! regular gas
Wasn't paying attention and put in a full tank of regular octane gas in the Teg yesterday. Will it hold up or do I need to get it out of there? I'm thinking just grandma drive the whole tank. Suck!
Old Jul 9, 2006 | 03:04 PM
b16adx's Avatar
Default Re: oops! regular gas (Boofster)
me i would just grandma it but i know that will be hard to do..plus you might forget as well....but id rather do that than go through the hassel of trying to drain the tank
Old Jul 9, 2006 | 03:17 PM
exotik4doorcivic's Avatar
Default Re: oops! regular gas (b16adx)
what i did was
pull the return line on the fuel pressure regulater
add a hose to the nipple
turn on the car and let it pour into a gas can until your on e
and then fill it up with premium
Old Jul 9, 2006 | 03:30 PM
vaporboy12's Avatar
Default Re: oops! regular gas (exotik4doorcivic)
or you can just pull the plug on the back left corner of the fuel tank
Old Jul 9, 2006 | 04:45 PM
eastbay92cx's Avatar
Default Re: oops! regular gas (vaporboy12)
Well unless your compression is much over stock you don't need that high octane unless you're boosting. Even at that...
I'd say don't worry about it.
edit: Take the spring out / disconnect the actuator on your wastegate
Old Jul 9, 2006 | 04:51 PM
Naterror's Avatar
you can always just get a can of octane booster and put it in. Then just try to stay out of any high boost if any boost until the tank is refilled.
Old Jul 9, 2006 | 05:11 PM
DRAGLS's Avatar
Default Re: (Naterror)
Dude don't listen to these people, just take it easy til the tank is almost empty it sucks but its not going to kill you. then fill back up with 93oct.
Old Jul 9, 2006 | 05:54 PM
Enzo Speed's Avatar
Default Re: (DRAGLS)
Pour in some toluene and start b00sting again
v8killaz
Welding / Fabrication
Sep 8, 2014 10:02 PM
Baodalazi
12
Mar 24, 2007 07:59 AM
kornerk12
Mar 18, 2007 09:13 AM
Red_Si
Oct 27, 2006 11:49 AM
Frozen E
Jan 24, 2005 05:39 PM
