Repaired Block
Old Jun 14, 2005 | 09:50 PM
Sille98's Avatar
Default Repaired Block
My F20B motor had been in an accident. (In Japan) well I ended up buying the motor unknowing of damage to the block. Anyways it had some broken bolts, and a major crack at the driver side motor mount. So here is the aftermath....
Old Jun 14, 2005 | 11:40 PM
speedinnovations's Avatar
Default Re: Repaired Block (Sille98)
How many amps did it take to pull that off?
Old Jun 15, 2005 | 06:28 AM
david@didrace.com's Avatar
I know on a 1' x 1' section of 3/8" thick aluminum I was pushing 350 amps with a preheat. I'm sure if you let the arc sit there for a while you can do it on a lower amperage with a preheat on something as large as a block. Never tried though, for the simple fact that it should still be machined flat, not ground down with a hand grinder. Hope you don't get any leaks.
Old Jun 15, 2005 | 02:35 PM
Sille98's Avatar
Default Re: Repaired Block (speedinnovations)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedinnovations &raquo;</TD></TR><TR><TD CLASS="quote">How many amps did it take to pull that off? </TD></TR></TABLE>
180 amps Pure Argon, no helium mix. AC of course...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">I know on a 1' x 1' section of 3/8" thick aluminum I was pushing 350 amps with a preheat. I'm sure if you let the arc sit there for a while you can do it on a lower amperage with a preheat on something as large as a block. Never tried though, for the simple fact that it should still be machined flat, not ground down with a hand grinder. Hope you don't get any leaks. </TD></TR></TABLE>
If it were on the other side of the block we would not have done it. Because of the location were confident it is going to seal fine.
**Head is in final stage of being torqued down. **
Old Jun 20, 2005 | 04:29 PM
DaveF's Avatar
i hope you used some copper spray at least.
TGonie
Welding / Fabrication
Aug 3, 2013 02:05 PM
efnfast1
Sep 18, 2006 06:58 PM
teamitr
Nov 17, 2005 07:09 PM
5STAR3
12
Oct 21, 2004 03:42 PM
philly-O
Sep 14, 2002 06:47 AM
