why is there squeaking when car starts?
Old Jun 14, 2005 | 08:39 PM
lotas's Avatar
Default why is there squeaking when car starts?
Not only that, but there is squeaking when I turn the AC on, I cant even run the AC because its so bad. What is this? What's the problem? Can any Altons or Les Schwab repair something like this? Thanks for the help guys.
by the way, its a 1999 accord 2.3L
Old Jun 14, 2005 | 08:57 PM
P_Adams's Avatar
Default Re: why is there squeaking when car starts? (lotas)
Your A/C drive belt is in serious need of tightening. As a matter of good mechanical sense, have all your drive belts inspected at the same time. You can save yourself the hastle of breaking down in East Overshoe somewhere.
P
Old Jun 14, 2005 | 09:30 PM
AccordRacing's Avatar
I had that problem VERY badly on my old car haha .. ::too lazy to fix it:: .. turned out .. all it needed was to tighten ONE SCREW that adjusted the tension.. soooooo .. get a Haynes manual .. look up checking belts .. and you should be capable of handling it yourself.
Old Jun 15, 2005 | 04:37 AM
JimBlake's Avatar
When the belts get old they get hard & slippery. Sometimes even when they're properly tightened they still slip & squeak. Maybe it's time for new belts...
Old Jun 15, 2005 | 04:50 AM
patastinky's Avatar
Default Re: why is there squeaking when car starts? (JimBlake)
Def check your belts.
If it's everytime then i would do this. Pour some water on the belt as it is moving.
turn the car off and then start it up again
if it's squeaks then either tighten it or loosen it accordingly. Or just replace it!
Old Jun 15, 2005 | 10:00 AM
goowakjai
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lotas &raquo;</TD></TR><TR><TD CLASS="quote">Not only that, but there is squeaking when I turn the AC on, I cant even run the AC because its so bad. What is this? What's the problem? Can any Altons or Les Schwab repair something like this? Thanks for the help guys.
by the way, its a 1999 accord 2.3L</TD></TR></TABLE>
its probably loose belts...if u kno how check and adjust them, and replace if neccessary. or have sumone else do it...
Old Jun 15, 2005 | 08:26 PM
lotas's Avatar
hey accord racing, where was that bolt?
How do I tighten the belt guys? The only thing I know how to do, is undo the bottom bolt of the alternator, and "lift" the alternator up, and obviously the higher you lift it the more tension on the belt. Then when you have it lifted up you have to tighten the bolt to hold the alt up in place. Is there something like a bolt you can just tighten that just tightens the pulley or belt or something? Thanks
Old Jun 15, 2005 | 08:39 PM
89_honda_accord's Avatar
Default Re: (lotas)
the belts well if there is no nut to tighten it like on my 89 acord onthe alternator belt i get a bar like a crow bar or flat piece of steel and use that and pry on the alternator carefully to NOT over tighten the belt i can get a belt tension guage on mine and i use that to be sure i don't over tighten it
jenbirge
Dec 21, 2022 01:55 PM
Turboteg00
Honda Civic (2001 - 2005)
11
May 4, 2010 01:39 PM
loadedB18C
Nov 7, 2004 01:39 PM
RnEpmc
Aug 22, 2004 08:53 PM
Integraholic
Jun 29, 2003 09:42 PM
