A/C problem
Old Jun 29, 2003 | 10:41 AM
Integraholic's Avatar
Default A/C problem
Ok, I had my AC belt disconnected for about 2 months and I finally put it back on a few weeks ago. Well a few days after, the AC quit. No weird noises or anything, the pump just wont engage anymore. Checked fuses and relays already, any ideas?
Old Jun 29, 2003 | 11:07 AM
AlphaKennyWun's Avatar
Default Re: A/C problem (Integraholic)
a small leak somewhere caused freon to escape. the compressor wont turn on without freon, get some
Old Jun 29, 2003 | 11:49 AM
jonoknut's Avatar
Default Re: A/C problem (S03Burner)
chekc the pressure see if you need to add some r134a
Old Jun 29, 2003 | 02:01 PM
Default Re: A/C problem (jonoknut)
Thanks, I'll check that out this week.
Old Jun 29, 2003 | 09:42 PM
4crx4me's Avatar
As per Helms:
You might want to check the receiver-dryer. If the system isn't used for a while, ie. belt removed, the dessicant inside goes bad. And, they are not repairable. Also, if compressor belt is left disconnected for long enough, I've been told they have a good chance of going bad.
The system needs the belt to keep the oil inside circulating.
Sounds like something for pro with the proper tools to check out 1st. though.
HTH
emooheo
Sep 14, 2010 12:16 AM
sinister357
Jul 28, 2007 06:36 PM
Cold Fyre
Aug 10, 2006 05:33 PM
DBAl
Jul 20, 2006 09:17 AM
rubens
Sep 4, 2003 08:23 AM
