Axel fitment
Old Jun 14, 2005 | 07:00 PM
BsmoothR's Avatar
Default Axel fitment
I am swapping my R swapwith 5 lug I had in a eg hatch back into a 97 R. What axels will work ?? The ones for the eg seem smaller.
Old Jun 14, 2005 | 09:39 PM
. o 69 o .'s Avatar
Default Re: Axel fitment (BsmoothR)
4 bolt or 5 bolt conversion?
if 4 bolt, your oem shafts should work fine,
if 5 bolt, it might have the 36mm hub, in which case you need JDM ITR shafts, or your oem shafts with 92-96 prelude vtec outters
Old Jun 15, 2005 | 08:56 AM
BsmoothR's Avatar
Default Re: Axel fitment (B16B)
Its 5 lug and the outer joints appear to be correct , the length seems to short.
Old Jun 15, 2005 | 07:57 PM
. o 69 o .'s Avatar
what engine is in your car? It should be fine for length because the itr hub ists int he smae place as the civic on did... only shaft length difference would be if you did a B-Series motor swap and tried to use the d-series axles
dasickestda9
Aug 25, 2006 04:07 PM
cilvia
Jun 12, 2005 05:46 PM
jdmcivR
Aug 13, 2004 01:33 PM
chameleon
12
Oct 4, 2002 10:22 AM
